Post Your All Motor JDM H22 Type S Piston Builds!
Old Sep 15, 2008 | 04:53 PM
VolkswagenWHO!!!'s Avatar
Default Post Your All Motor JDM H22 Type S Piston Builds!
Alright guys. Haven't seen one of these threads yet so I decided to try to get one going. Lets see your H builds with OEM Type S Pistons. So we can see the power limit and potential of the JDM Type S Pistons. Dyno numbers, track times, helpful info and tips for other users.
My current set up isn't done yet, but ill put it up when its done
Alright guys, lets see em!!!
Modified by VolkswagenWHO!!! at 6:21 PM 9/16/2008
Old Sep 15, 2008 | 05:09 PM
GhostAccord's Avatar
Default Re: Post Your All Motor JDM H22 Type S Piston Builds! (VolkswagenWHO!!!)
Not to be an A$$ but that grocery list you posted up there looks like it contains a wee bit more than just JDM Type S pistons only !
Old Sep 15, 2008 | 05:12 PM
Default Re: Post Your All Motor JDM H22 Type S Piston Builds! (GhostAccord)
I dont see whats so confusing about it. People do builds with CTR and ITR pistons in B series correct? The only difference is im talking about H's and the JDM type S pistons.
Old Sep 15, 2008 | 05:38 PM
I never said I was confused.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VolkswagenWHO!!! &raquo;</TD></TR><TR><TD CLASS="quote">Lets see your H builds with OEM Type S Pistons only!</TD></TR></TABLE>
I merely pointed out that you are using more than just type S pistons in your build. And that you have asked for H22 builds that used "only" type S pistons. Does this clear up any confusion for ya.
That's all I was trying to say
That and the fact that the 6 of these threads posted per week are boring
That is a nice grocery list ya got there. Have you built it yet?
Oh that's right, you mentioned that your guessing that your list of parts may net you 11.5ish CR & 250ish Hp. So I will assume that this build is still in boxes on the store shelves.
Well good luck with your build
Old Sep 15, 2008 | 05:57 PM
Don't worry about my "grocery list". If you dont have anything useful to post relating to the topic then go somewhere else with your BS. Anyways come on guys lets see them!
Old Sep 15, 2008 | 06:34 PM
racebucket_eg's Avatar
Bump for an interesting thread.
Old Sep 16, 2008 | 05:30 AM
TTT Come on guys almost 100 views and no takers?
Old Sep 16, 2008 | 07:20 AM
AllMotorRandy's Avatar
i think maybe utilizing an h23 crank will be a sure fire way to attain your goal.
Old Sep 16, 2008 | 11:33 AM
Default Re: Post Your All Motor JDM H22 Type S Piston Builds! (AllMotorRandy)
I think I just might do that. Thanks for the advice. Although this thread im trying to start doesnt seem to be kicking off they way I expected. Come on people I know im not the only one who is using these pistons.
Old Sep 16, 2008 | 11:37 AM
who did the work on the head?
Old Sep 16, 2008 | 12:17 PM
Randy you got PM
Old Sep 16, 2008 | 12:42 PM
pjhatchin's Avatar
The setup before I tore it down due to faulty piston ring scroing up cylinder #1:
h22 with type s pistons
h23 crank and rods
h22a head no porting
Skunk pro 2 manifold
Pro 2 cams
70mm tb
SSR Side exit
Made 235 hp 172 ft pounds before cylinder #1 starting losing a **** load of compression. PED was thinking it would of made somewhere between 240-250 hp. I'm now doing an f2b with the 97 crank hope to make 250+.
Old Sep 17, 2008 | 03:32 PM
misterpsycho's Avatar
223.51hp 166.94tq
H23 crank & rods
H22 Type S pistons .025 OS
H22A4 head (no porting done)
Crower 3 cams w/ RM springs & retainers
Euro-R intake manifold
Professional Products 68mm ITR throttle body
shitty DC header (because i had placement issues with my race header)
Old Sep 17, 2008 | 04:15 PM
GoldLudeRay's Avatar
also running type s pistons but on a h22 crank and rods
it is running a sk2 manifold,camp1320 header, sk2 stg 2 cams, skunk flat faced valves and a milled head,,,,,, hoping for about 12.0.1 cr and im running e85
this motor is in pieces right now lol
Old Sep 17, 2008 | 09:52 PM
jeff652's Avatar
Default Re: (GoldLudeRay)
The H22 Type S Pistons have weak ring landings, just like all the H22 pistons. I made 240hp/180tq at the wheels on my H23VTEC - but the ring landings failed in all four cylinders at the first track day. Yes it was fully tuned, broken in, etc etc.
Here's a pic of the pistons after they blew:
It was a wicked setup while it lasted. I should have done it right - sleeved the block and used forged pistons. OEM H series pistons can't handle that much power
Old Sep 18, 2008 | 04:21 PM
Ferarrikiller's Avatar
Default Re: (jeff652)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jeff652 &raquo;</TD></TR><TR><TD CLASS="quote">The H22 Type S Pistons have weak ring landings, just like all the H22 pistons. I made 240hp/180tq at the wheels on my H23VTEC - but the ring landings failed in all four cylinders at the first track day. Yes it was fully tuned, broken in, etc etc.
It was a wicked setup while it lasted. I should have done it right - sleeved the block and used forged pistons. OEM H series pistons can't handle that much power</TD></TR></TABLE>
sorry to hear about that. What kind of piston rings were you running? Were those OEM pistons or the Nippon's?
I am putting together an h22 with type s pistons and I'll be running pro 1's with bolt ons looking for about 210 wheel. I'm using OEM rings and OEM type s pistons
the head got finnished this week and I'll be dropping off the pistons and rings on monday so we'll see what happens.
Old Sep 18, 2008 | 05:08 PM
bluedlude's Avatar
yeah, those are definitely not OEM type S pistons.
Old Sep 18, 2008 | 05:51 PM
g0tuj0ckin's Avatar
Default Re: (bluedlude)
wut intake manifold r u guys running on these setups?
Old Sep 18, 2008 | 05:55 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluedlude &raquo;</TD></TR><TR><TD CLASS="quote">yeah, those are definitely not OEM type S pistons.</TD></TR></TABLE>
I was going to say the same thing. Those definitly arent OEM pistons
Old Sep 18, 2008 | 08:10 PM
jeff652's Avatar
Be careful, you might stick you foot in your mouth without realizing it . . .
Just because you've never seen an OEM H22 Type S Piston with an aftermarket molly skirt before doesn't mean they don't exist.
Because I'm a nice guy, here's a pre-installation picture:
And a couple from the track after we blew it up:
I'll post the video of the dyno tuning if you ask nicely . . .
Old Sep 18, 2008 | 08:33 PM
tealchief's Avatar
pretty please?
Old Sep 19, 2008 | 05:13 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jeff652 &raquo;</TD></TR><TR><TD CLASS="quote">I'll post the video of the dyno tuning if you ask nicely . . .</TD></TR></TABLE>
Please... lol. How high were you revving the car?
Old Sep 21, 2008 | 08:09 AM
Lets see some more!
Old Sep 21, 2008 | 09:22 AM
cdownin's Avatar
Dam what are you guys doing to theses motors... these are OEM pistons not racing pistons... I am using these pistons on my daily driver and I hope I don't have these type of problems because I don't wanna take the bus... and Please if your going to drag race your car on tha track and beat on it... please get forged pistons... I don't wanna see anymore pics it is just making me nervious I have spent a lot of my money on this build and I don't wanna see it go up in smoke....
Old Sep 21, 2008 | 03:03 PM
Default Re: Post Your All Motor JDM H22 Type S Piston Builds! (cdownin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cdownin &raquo;</TD></TR><TR><TD CLASS="quote">Dam what are you guys doing to theses motors... these are OEM pistons not racing pistons... I am using these pistons on my daily driver and I hope I don't have these type of problems because I don't wanna take the bus... and Please if your going to drag race your car on tha track and beat on it... please get forged pistons... I don't wanna see anymore pics it is just making me nervious I have spent a lot of my money on this build and I don't wanna see it go up in smoke....</TD></TR></TABLE>
**** happens. Thats the risk you take to be different. Like I told the last guy if you dont have anything good to contribute to this thread then dont post please.
