VSS testing without harness (DOING THIS RIGHT NOW, IN A BIND)
Old Sep 15, 2008 | 04:34 PM
marks97el's Avatar
Default VSS testing without harness (DOING THIS RIGHT NOW, IN A BIND)
I have a 97 EL and speedometer was acting (and the CEL came on) up so i checked my VSS. The middle terminal on the sensor was corroded and acctally fell out when i touched it with a multimeter probe. So i got a VSS from a wrecker. I installed it and just took it for a 2 or 3 minute spin. The speedometer still does not work but i no longer have a CEL.
I want to do the diagnostic tests without the HARNESS.
The VSS has a Blue with White stripe, black with yellow strip, and all black wires.
I was wondering which clips (red, green, white) correspond with which wire?
Also, in the event the middle plug is coated with corrosion, how do you reccomend cleaning it?
Old Sep 15, 2008 | 04:41 PM
marks97el's Avatar
Default Re: VSS testing without harness (marks97el)
I checked continuity between the each wire and ground.
All black, continutiy
Black w/ yellow, continuity
Blue w/ White, NO CON'T
Modified by marks97el at 9:18 AM 9/17/2008
Old Sep 15, 2008 | 05:17 PM
marks97el's Avatar
Well, I figured out the harness situation.
RED CLIP = blk
WHITE CLIP = blk/yel
GREEN CLIP = blu/wht
That should help people when this thread is archived.
My problem is that the blu/wht wire is not properly connected in the harness.
Sometimes it will show just under 5V on the voltmeter, but when i barely tug on the plug the voltage disappears.
Thank god i don't need a new speedo.
Modified by marks97el at 9:17 AM 9/17/2008
Fliptard
Feb 28, 2012 07:11 PM
iHOPEyouCHOKE
May 22, 2006 07:29 PM
iHOPEyouCHOKE
May 22, 2006 01:31 PM
JCracer723
Dec 4, 2003 04:30 PM
sanders711
Oct 12, 2002 10:28 PM
