Rod/bearing thrown in my GSR today :(
Old Sep 15, 2008 | 03:19 PM
Shocka1998LX's Avatar
Default Rod/bearing thrown in my GSR today :(
My oil light comes on, I pull over, check the oil.... add oil because my dipstick was giving me a sketch reading. A ratting sound starts... increases in frequency, I could feel it through the gas pedal. I was about 3-5 minutes from my local race shop so I put on the hazard lights and went slow as hell over there. When I arrived I was reassured by the owner that my intuition was correct and there was probably a serious issue with my bottom end -- probably a thrown rod or bearing.
So we start talking options, and I'm traumatized because this is alot of money that I really dont need to be spending right now. But realistically I need to think about it pricewise vs motor effectiveness and reliability.
I came out with the idea of doing a b20/vtec. The torque is good. I know the walls are thin, but I'm only wanting to push it into the 200whp area. Thoughts, opinions, suggestions, etc, all are wanted.
oh yeah this is /end vent
RIP GSR
Old Sep 15, 2008 | 04:20 PM
help me any suggestions would be ideal.. if you can put yourself in my situation for a sec
Old Sep 15, 2008 | 06:16 PM
geebs's Avatar
Default Re: (Shocka1998LX)
have you removed the oil pan yet? drain the oil and remove the pan.. see what the damage actually is.. go from there..
b20/vtec would be sweet tho...
Old Sep 15, 2008 | 06:36 PM
stock ek's Avatar
Default Re: (geebs)
i would def check the damage first, even though from the way you said it, it sure sounds like a bearing but i would check, b20vtec would be sweet and pretty affordale i think hmotorsonline is selling b20 long blocks for like 500 give or take a few but good deal i think.
Old Sep 15, 2008 | 06:55 PM
alphalanos's Avatar
Default Re: Rod/bearing thrown in my GSR today :( (Shocka1998LX)
damn that sucks. Always liked your car. Good luck with the new motor choice. Torque is always good lol.
Old Sep 15, 2008 | 07:14 PM
gsrhatch2356's Avatar
Default Re: Rod/bearing thrown in my GSR today :( (alphalanos)
why not just get a new crank and rod assy. hell if you are really trying to save money then just pull it out have it cut and micropolished and use oversized bearings.
Old Sep 15, 2008 | 07:21 PM
kuja396's Avatar
Default Re: Rod/bearing thrown in my GSR today :( (gsrhatch2356)
Thats a spun bearing, if it was a thrown rod, I would have seen a nice window-in-the-block pic
Sucks, but not crazy bad, like what was said before, ls/v or just get the crank micropolished, good luck
Old Sep 15, 2008 | 08:16 PM
jdm_dc_fan's Avatar
From: "That one guy with that one car" Kennewick WA
same thing happend to me 5 years ago and saved myself the trouble and threw in a new longblock and sold the head.
Old Sep 15, 2008 | 09:22 PM
94EG8's Avatar
Seagull Management
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrhatch2356 &raquo;</TD></TR><TR><TD CLASS="quote">why not just get a new crank and rod assy. hell if you are really trying to save money then just pull it out have it cut and micropolished and use oversized bearings.</TD></TR></TABLE>
X2, If it were me I think i'd try a new crank rod and main bearings and new connecting rods. Or a long block and sell the old head.
Old Sep 16, 2008 | 08:44 AM
EkFG's Avatar
Default Re: Rod/bearing thrown in my GSR today :( (94EG8)
just take it apart and have the crank checked then go from there maybe you can save your crank. thats what i did but my bearing wasnt too bad. take that **** to a machine shop and they will check her out.
Old Sep 16, 2008 | 10:51 AM
It'd be easy if I had worked on a block before but I haven't
And the part of town it spun a bearing is pretty isolated, so a drive anywhere would be no good at all. Luckily it was right near Trackmasters though. They know whats up when it comes to hybrid builds. They have a b20 on the way right now. They'll use the head from my GSR. Afterwards I'll tinker with my F'd up GSR block and learn a thing or two
I'll be buying a hytech replica header for it
Old Sep 16, 2008 | 11:09 AM
boosted ls vtec's Avatar
keep the old block i'll buy it.
Old Sep 16, 2008 | 02:51 PM
I'll have to see what shape it's in but I'll let you know
Old Sep 16, 2008 | 07:09 PM
EM1SiR85's Avatar
From: everywhere., cali,nevada,new york., united states
hell yea! b20 block. sleeve it to a 2.2. pistons. and a gsr head!!! heelll yeaaaa boy.
im working on mine also.
Old Sep 16, 2008 | 08:01 PM
I cant afford to sleeve it right now, I'm a working college student on a budget. Maybe hondas will be a vicious cycle and I'll get the busted b18c sleeved, swapped back in and boosted... and take the old b20 block and do just that, 2.2 all motor on an EF sedan
Modified by Shocka1998LX at 5:32 AM 9/17/2008
Old Oct 3, 2008 | 12:58 PM
speed bump's Avatar
Interested in hearing how this went.
Good luck!
Old Oct 3, 2008 | 03:06 PM
Schister66's Avatar
Man U FTW
Pull the oil pan, replace the rod bearings (and the mains while you're at it), replace the rod or have it checked for out-of-round and put 'er all back together. You dont have to pull the motor if you do it right...
d15Beta
Jun 9, 2011 04:30 PM
cashshoes
Nov 24, 2007 11:22 AM
gsr_b20x2
Oct 4, 2005 08:05 AM
Unsivil_audio
Jan 19, 2005 11:23 AM
espanol
Apr 20, 2003 10:04 AM
