Got my car tuned today
Old Jul 25, 2002 | 04:58 PM
JMinSi2000's Avatar
Default Got my car tuned today
I got 232 whp out of it. Its a 2000 Civic Si. What do you think I should be able to run on Nitto drag radials if I get a 2.0-2.1 60' out of it?
Old Jul 25, 2002 | 05:07 PM
SlowB16's Avatar
Default Re: Got my car tuned today (JMinSi2000)
go to the track and find out
Old Jul 25, 2002 | 05:10 PM
JMinSi2000's Avatar
Default Re: Got my car tuned today (SlowB16)
I'm goin tommorow. Hopefully it'll be cooler than the 108 degrees that it was in the shop.
Old Jul 25, 2002 | 05:23 PM
teamrocket si's Avatar
How much boost were you running? what's your set up?
Old Jul 25, 2002 | 05:26 PM
JMinSi2000's Avatar
Default Re: Got my car tuned today (teamrocket si)
drag3 kit at 8psi
Old Jul 25, 2002 | 06:45 PM
93LSivic's Avatar
13's
Old Jul 26, 2002 | 11:49 PM
JMinSi2000's Avatar
Default Re: Got my car tuned today (93LSivic)
Well...heres my best slip:
R/T .880
60' 2.241
1/8 9.096
MPH 80.70
1/4 13.922
MPH 100.61
With the nitto drag radials I was finishing in 5th gear. Would a taller tire help me?
Old Jul 26, 2002 | 11:55 PM
IntegD's Avatar
New User
You have a 00 SI and you trap at 100, but you finished in 5th gear? How is that possible, I thought that 4th gear at least went to around 110ish? Gsr supposively goes to around 119 in 4th, I know the SI gearing is a little closer, so I am pretty sure you would be in 4th right?
Old Jul 27, 2002 | 12:15 AM
JMinSi2000's Avatar
Default Re: Got my car tuned today (IntegD)
Running a 45 series tire instead of a 55.
Old Jul 27, 2002 | 01:12 AM
Tofurky's Avatar
yeah. at least from what i remember, i was finishing a little into fourth gear
Old Jul 27, 2002 | 09:43 AM
JMinSi2000's Avatar
Default Re: Got my car tuned today (Ruckus138)
Using a shorter tires shorens your gear ratio...making you finish in a different gear. If I were to run on my stock tires, yes, I would finish in 4th.
Dr. Gonzo
12
Jun 23, 2009 11:34 PM
a1320honda
May 16, 2009 06:40 AM
killerpenguin21
Transmission & Drivetrain
25
Dec 5, 2008 09:25 PM
stizzit
Apr 23, 2004 11:23 AM
97integraLST
Nov 11, 2001 10:21 AM
