3rd gear pull, spark plugs are brite white!! lean??
Old Sep 15, 2008 | 08:50 AM
b20vtech's Avatar
Default 3rd gear pull, spark plugs are brite white!! lean??
ok, bought some new plugs, took it for a test drive, did a 3rd gear pull and shut off engine at 8k rpm, pulled over to the side and pulled out spark plug # 1 and it was white! is this a lean mixture? also checked it with normal driving and its white too.. this is on a stock b20vtec motor. I get about 26-28mpg with this thing.
Old Sep 15, 2008 | 09:05 AM
bigkvn77's Avatar
Default Re: 3rd gear pull, spark plugs are brite white!! lean?? (b20vtech)
yes white means its running lean. a little bit of white is ok. If the entire plug is white and heavily coated thats not good.
Old Sep 15, 2008 | 09:34 AM
DonF's Avatar
A white insulator is fine, as long as there are no little black spots. Those are the start of detonation, any Al specs and you have had detonation. The color ring to check the fuel is at the bottom of the insulator where it meets the metal housing, to read it you usually need a magnafying glass and light source.
Old Sep 15, 2008 | 09:44 AM
b20vtech's Avatar
Default Re: 3rd gear pull, spark plugs are brite white!! lean?? (DonF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF &raquo;</TD></TR><TR><TD CLASS="quote">A white insulator is fine, as long as there are no little black spots. Those are the start of detonation, any Al specs and you have had detonation. The color ring to check the fuel is at the bottom of the insulator where it meets the metal housing, to read it you usually need a magnafying glass and light source.</TD></TR></TABLE>
how big are those little black spots suppose to be? i do see some but they are very very tiny ones. they are smaller than this black spot . &lt;---
Old Sep 15, 2008 | 10:09 AM
DonF's Avatar
You want no black spots, retard the timing 2 degrees, or bump the octane.
Old Sep 15, 2008 | 10:33 AM
98vtec's Avatar
moderator emeritus
https://honda-tech.com/zerothread?id=2315208
Old Sep 15, 2008 | 12:33 PM
b20vtech's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF &raquo;</TD></TR><TR><TD CLASS="quote">You want no black spots, retard the timing 2 degrees, or bump the octane.</TD></TR></TABLE>
ok i will try that.
TeGGY_LS
12
Jul 24, 2008 08:36 AM
axionm1k
Jul 17, 2008 05:02 PM
elikas
Jan 18, 2007 07:40 PM
hondaeg8
Jan 21, 2004 04:53 PM
dc4drewH
Dec 28, 2003 07:11 AM
