crap, how do i install the bolt on the downpipe in the sharp bend?? MAV-REV setup btw!
ok i have the maxrev setup and the bolt is next to impossible to put on, i even bought different sized bolts to see if i could squeeze one in, no luck. seems i may have to use a stud and nut or not use that bolt at all
now i know why drag put that bolt on before they weld the flange!
Yes you are right, I have the max-rev kit and you must use a stud AND you will actually have to grind on the nut to get it on tight. I had to do this on my kit anyways. Good Luck
grind on the nut? gheeese!
hopefully i can find the right parts at napa, my local store has a huge assortment. arrrg nothing ever goes smooth
8mm x 1.25
you might have to cut the stud just a lil bit so the nut will have a room to fit under the bend
stan
stan
tianporn
11
Dec 13, 2014 04:03 PM
boostincoupe
Aug 3, 2006 09:20 PM
StolenTeg
Aug 24, 2005 02:46 PM
