what is P1503?
Old Sep 15, 2008 | 06:12 AM
chickenwing's Avatar
Default what is P1503?
I checked in the honda manual and it only has P1498 or P1508.
anyone know?
Old Sep 15, 2008 | 06:23 AM
Syndacate's Avatar
Default Re: what is P1503? (chickenwing)
How did you obtain said code?
You can only get "P" codes with an OBD-II Scanner (meaning your car has to be A) Scanned with an OBD-II scanner, and B) '96 or above). You can't use the jumper thing to obtain P codes, only standard OBD-I codes. So you should know exactly what it is because it should tell you on the screen...or if you have one of the cheap *** ones that won't tell you, you read it off the scanner wrong.
Old Sep 15, 2008 | 09:47 AM
gsrhatch2356's Avatar
I would say check again. I dont know what vehicle you have but I put in a few diffrent ones 96 and up and none of them carry a p1503 code.
Old Sep 15, 2008 | 03:35 PM
Default Re: what is P1503? (gsrhatch2356)
yes it is a canadian 1997 civic ex sedan model.
it originally comes with a Y7 but I just swapped in a Y8
i used this innova obd2 scanner
Old Sep 15, 2008 | 07:10 PM
like I said I would check it again or try a diffrent scanner. there is no listing for a 1503.
Robotn1x
Sep 7, 2012 03:51 AM
dookeye
Jan 24, 2010 11:53 AM
2good
Nov 2, 2008 01:15 AM
ensracer
Oct 31, 2004 08:07 AM
stock97
Mar 25, 2003 03:09 PM
