ABS issue after brake upgrade
I got the abs kicking in when the brakes are applied and the speed nears almost a dead stop.
Before when I had the stock 9 inch brakes everything was fine.
After i put in rebuilt calipers, new rotors, new pads, new stainless steel lines, new wheel bearing into the integra spindle I have this problem.
There is not leaks, no air in the system after gravity bleeding them.
I have cleaned the abs sensors before installing them.
what gives?
what gives?
