Bird/ chirping sound coming from the engine (D16Y8)
Old Sep 14, 2008 | 11:18 PM
RICE POLICE SIP's Avatar
Default Bird/ chirping sound coming from the engine (D16Y8)
I've tried searching and I just don't know what to search for I guess.. But a recently rebuilt motor was put in and it idles fine and doesn't over heat or anything but at idle it kind of sounds like a bird chirping sound coming from the engine. If someone knows what this could be please let me know... And it's not a squeal like a loose belt sound... TIA
Shane
Old Sep 15, 2008 | 01:14 AM
MugenEH3's Avatar
Default Re: Bird/ chirping sound coming from the engine (RICE POLICE SIP)
Could be one of your belts, have you checked them to see if theyre okay?
Old Sep 15, 2008 | 05:31 AM
Default Re: Bird/ chirping sound coming from the engine (MugenEH3)
I've only got the timing and alt. belt.. it's not them...
Old Sep 15, 2008 | 05:38 AM
00b20vtecoupe's Avatar
my friend had air coming out of his intake at idle on a d16 and it sounded like a whistle... i dont know y but the air was coming back out the intake instead of in to the motor.
Old Sep 15, 2008 | 06:48 AM
geebs's Avatar
Default Re: Bird/ chirping sound coming from the engine (00b20vtecoupe)
could be a bearing problem.. oil starvation..
Old Sep 15, 2008 | 07:44 AM
xblind assassinx's Avatar
what about your pulleys?
Old Sep 15, 2008 | 07:57 AM
davefromPA's Avatar
do you have the tube from the valve cover running to the intake tube? my car wistled before i got a breather and covered the hole on the intake tube.
Old Sep 15, 2008 | 09:59 AM
halocore's Avatar
my car had a chirping sound back then too, but that was only because my wire harness was rubbing against one of my belts, I caught it in time before anything worst could happen.
Old Sep 15, 2008 | 10:04 AM
1.5Slowmatic's Avatar
do you have an intake? My y8 with an intake has a chirpping/ bird sound at about 3k rpms. Ive been told it could be the TB gasket and also the breather setup and to just unplug the hose from the black box on the back and plug it back in
Old Sep 15, 2008 | 12:52 PM
Pothole987's Avatar
Default Re: (1.5Slowmatic)
alt belt could be a little wore out
Old Sep 15, 2008 | 04:39 PM
guinnessstout's Avatar
Default Re: (Pothole987)
by chance have you listened to the alt. itself sometimes the shaft bearing will start to fail and it sometimes makes the chirp noise
Old Sep 11, 2010 | 05:13 PM
Howard490's Avatar
Default Re: Bird/ chirping sound coming from the engine (D16Y8)
Check your coolant level or under the car for any leaks. An erratic chirping noise is a very common symptom of a failing water pump. Run the car till it's hot and then park it and turn it off then check the weep hole and see if any coolant Is leaking out. If it is, it's your water pump. Good luck!
mmmbrapND
Apr 15, 2013 05:18 PM
Landshark68
Honda Civic (2006 - 2015)
10
Sep 29, 2007 04:46 PM
totalimpact
Aug 17, 2004 08:44 AM
ATS*Mark
10
Aug 21, 2003 01:57 PM
DeBo
13
Mar 12, 2003 07:52 PM
