Idle Drops/Struggles When Headlights Are On. Help Me Find The Culprit!
Old Sep 14, 2008 | 10:11 PM
fms1day's Avatar
Default Idle Drops/Struggles When Headlights Are On. Help Me Find The Culprit!
Video: (Sorry it's a bit out of focus but I think you can still see what's going on. Towards the end, it actually drops low enough to stall the car.)
http://www.youtube.com/watch?v=C4LKaQ1fNfw
Alright, I need help figuring out what the culprit is that's causing this:
My idle doesn't seem to hold when the headlights/foglights are on. For example, night driving.
When I reach a stoplight and sit there, the idle starts to struggle, sometimes dropping as low as near stall where the cluster lights dim.
The idle also seems to be affected when I'm holding down the brakes. If I release the brake pedal quickly, the idle surges back up.
Anyone have any idea what's causing my idle to drop? It seems electrical somewhat? Since it seems to occur more frequently when the headlights/foglights/brake lights are on.
Old Sep 15, 2008 | 07:08 AM
fms1day's Avatar
Default Re: Idle Drops/Struggles When Headlights Are On. Help Me Find The Culprit! (fms1day)
bump
Old Sep 15, 2008 | 07:21 AM
addiction2bass's Avatar
IMO could be your battery conections. and or ground cables....
take off your battery wires and clean them really good with a wire brush and put some dieelectrical grease on the terminals to keep them from coroding up. and if your ground wire has any green on the wire around the rubber coated areas then replace the wire! the corosion is on the inside of the wires.
dont forget about the front motor ground and side tranny ground wires. those 2 wires always seem to be striped back and easy exposed wires for dirt and rust to hurt current flow.
and if all of the wires and conections look good then take your car into a autoparts store that does free alternator/battery tests and have your alternator and battery tested out and replace if weak.
Old Sep 15, 2008 | 02:32 PM
fms1day's Avatar
Default Re: Idle Drops/Struggles When Headlights Are On. Help Me Find The Culprit! (addiction2bass)
sounds like a good place to start.. thanks.
live4soccer7
13
Oct 12, 2022 02:38 AM
95_Civic_4dr
Dec 13, 2009 09:14 PM
ludedude808
Nov 5, 2006 10:44 PM
PINKS
19
Jul 25, 2006 03:47 PM
teewhy55
12
Dec 29, 2004 07:23 AM
