Hatch Si owners rejoice! leakin sunroof info
Well I was about to drive home last night after it had been raining for a couple hours, and as I was pulling out, my headliner started to gurgle like the old familiar "I'm gonna dump two gallons of water on you and laugh" sorta sound. So I decided it was time to find the rear drain tubes for the sunroof, and I finally found them. They can be found behind your interior plastic covers. If you pull the side one off, the one you would take off to change your light bulbs, reach back and you can feel a tube. That tube, about a half inch in diameter, is your drain tube. Pull it out of its 90 degree turn, which puts the water outside the vehicle, and see if its clogged.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shaggyeg6si »</TD></TR><TR><TD CLASS="quote"> "I'm gonna dump two gallons of water on you and laugh"</TD></TR></TABLE>
hahahahahaha one of the best lines ive ever herd
green91
12
Feb 1, 2006 11:00 AM
Mike Panic
Aug 15, 2004 05:18 PM
GroundZer0 336
Mar 15, 2003 05:29 AM
