Honda S2000 Honda S2000
Help with installing DEI window modulator
Old Sep 14, 2008 | 11:27 AM
fujimi's Avatar
Default Help with installing DEI window modulator
me and a friend tried to installed the DEI 530T window mod. on my06 and now the pass. side window doesn't work.
it goes down ONLY if you put the top down. otherwise I can't put it down. I can roll it up on driver side only. The switch on the pass. doesn't do anything.
Anyone have experience with installing the window modulator?
Its so you can auto roll down/up on both side etc.
Thanks
Old Sep 14, 2008 | 01:42 PM
bigmacnfries's Avatar
Default Re: Help with installing DEI window modulator (fujimi)
sounds like you've knocked the window lock button on the driver side door.
someone else did this on here about a month ago. though they later went on to deny it...
Old Sep 15, 2008 | 04:07 AM
White Smoke's Avatar
i my honda
Global Mod
Default Re: Help with installing DEI window modulator (bigmacnfries)
Yeah it does sound like you just flipped the window lock switch. The top down switch overrides the lock so that would explain why it goes down with it locked.
If this is not the case, let us know where you mad the connections for the 530T.
Old Sep 16, 2008 | 04:30 PM
fujimi's Avatar
^^ im not really sure where the connection went wrong. My friend does alarms for nissan dealerships so i was hoping he would know more then i did.
So I should check the window lock button wire to see if there is any problems?
tia
Old Sep 16, 2008 | 04:50 PM
i my honda
Global Mod
Default FV-QR
I was just saying see if it is locked... I need to know where exactly you made the connections to be of anymore help.
Old Sep 20, 2008 | 04:58 PM
fujimi's Avatar
my friend spliced the connection for the 530t and the pass. window doesnt go down as fast as the driver side. it only drops it 2 inches at a time instead of lowering it all the way.
you guys dont happen to have the service manual for the 06 by any chance? or wiring diagram would be great
jerBEAR
Honda Civic (2001 - 2005)
Sep 6, 2010 06:11 PM
gqstatus05
Oct 23, 2008 08:51 AM
92ehatch
Mar 3, 2006 02:49 AM
CNSK
Aug 19, 2005 07:07 AM
