GSR Swap Problems...
Old Sep 14, 2008 | 08:56 AM
chris3385's Avatar
Default GSR Swap Problems...
Well I've searched and searched and checked everything I can pretty much check. Just wondering if anyone has any ideas..
I have a 92 Civic and a JDM GSR motor swap. Everything seems to be in working order. The motor will start if I shoot a shot of brake clean in the throttle body and run until that burns up but idles fast. I pulled the injectors out and they are squirting out fuel. Tried a brand new main relay, new fuel pump, have fuel pressure set at around 40psi. We tried messing around with the fuel pressure but still doesn't make a difference. Does anyone have any idea's? It seems as if the injectors just aren't squirting enough gas....
I have a brand new set of 550cc injectors I tried just for the hell of it and the car would start up and idle for about 40 seconds by itself then die.... Wouldn't start great but it would start and idle..
Any ideas or comments would be appreciated.
Thanks,
Chris
Old Sep 14, 2008 | 09:43 AM
civicjoe's Avatar
Default Re: GSR Swap Problems... (chris3385)
Check and make sure that the timing is set right and the dizzy set at 16 degrees. Otherwise your getting spark and fuel. hmmm how about your grounds are they all good?
Old Sep 14, 2008 | 11:36 AM
chris3385's Avatar
Default Re: GSR Swap Problems... (civicjoe)
Timing is dead on. Grounds are all good. Tried a different dizzy today just to narrow it down a bit... never made a difference.
Old Sep 15, 2008 | 03:03 AM
chris3385's Avatar
No one has any ideas??
Old Oct 4, 2008 | 08:47 PM
bikewithnoname's Avatar
check your fuel air ratio. get a guage and test it. id try o2 sensor maybe. sounds like its burninng way to lean but its reading that its ritch. test the fluxuation of the sensor if it doesnt fluxuate you have a problem. im no pro. but my car did the same thing. my o2 sensor wasnt fluxuating so i figured it was jsut dead. turned out the harness had a break. fixing both problems cured my problems. test the resistance of your harness from ecu to plug. it could be a world of problems good luck man. ill ask a few friends for advice ill see what else i can dig up
Old Oct 5, 2008 | 05:18 AM
B.'s Avatar
B.
400 HP Club
make sure your TPS and MAP sensors are not flip flopped.
Old Oct 5, 2008 | 05:28 AM
fortymcpants's Avatar
Default Re: GSR Swap Problems... (B.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B. &raquo;</TD></TR><TR><TD CLASS="quote">make sure your TPS and MAP sensors are not flip flopped. </TD></TR></TABLE>
best advice right there, actually check all the connections on the intake manifold.
and what ecu are u using
Old Oct 19, 2008 | 06:29 PM
mikeledez_ho!'s Avatar
Default Re: GSR Swap Problems... (fortymcpants)
which connections and what is iab's????????? cuz im having the same problems
HELP US!!!!!!!
harley78
Dec 22, 2014 03:12 AM
Luke 91 ef
Jan 24, 2013 10:40 AM
ohsnapzafingcu
15
Jun 7, 2010 09:07 PM
chris3385
Oct 7, 2008 11:43 AM
Fezzie
Mar 25, 2007 05:29 PM
