pistons....
Old Sep 13, 2008 | 10:38 PM
ERKK's Avatar
Default pistons....
i have a d16a6 block and i have a set of z6 pistons laying around i wanted to know if they would work in the a6 someone told me the deck hight was diffrent but if my rods it should be the same right?
Old Sep 13, 2008 | 11:08 PM
ERKK's Avatar
Default Re: pistons.... (ERKK)
Old Sep 14, 2008 | 06:04 AM
jlicrx's Avatar
Z6 pistons will work in the A6, however, with A6 head your compression ratio will drop to around 8.4:1
Old Sep 14, 2008 | 06:56 AM
ERKK's Avatar
im runing a z6 vtec head so what would it be then?
Old Sep 14, 2008 | 07:11 AM
ERKK's Avatar
and will i have to us my rods
Old Sep 14, 2008 | 08:08 AM
DCRB's Avatar
Default Re: (ERKK)
i'd like to know about this as well, i have a set of z6 pistons and rods and will be rockin the a6 bottom with the z6 top
Old Sep 14, 2008 | 09:08 AM
Johnny-Red's Avatar
Default Re: (DCRB)
Wouldn't Z6 Pistons with a Z6 Head make then motor basically a bastard Z6? With the same compression as a stock Z6 depending on head gasket and milling of course?
Old Sep 14, 2008 | 10:54 AM
ERKK's Avatar
bumpppp help me out here
Old Sep 14, 2008 | 05:23 PM
ERKK's Avatar
bump i need to know asap plz
Old Sep 14, 2008 | 07:06 PM
91_shoebox_Si's Avatar
i recently did a mini-swap with a y8 head and rebuilt my a6 block using z6 pistons and rods. my idea was to have the mini swap and still have compression in the 9's for turbo down the road without using vitaras or expensive turbo pistons. i've had it running for about 1500 miles now with no issues at all. so yes, in my experience, you can use z6 pistons and rods in an a6 block with no issues. it will just lower you're compression from using the stock a6 pistons. compression according to the calculator on c-speed would be around 9.1:1. check it out here...
http://www.c-speedracing.com/h...c.php
Modified by 91_shoebox_Si at 8:18 PM 9/14/2008
Old Sep 14, 2008 | 08:03 PM
ERKK's Avatar
well i was to get some z6 pistons for free anyone selling any plz need ASAP with rods and everythign
Old Sep 14, 2008 | 09:05 PM
Default Re: (ERKK)
i don't have any z6 pistons but i do have a set of a6 pistons and rod if you want em.
Old Sep 14, 2008 | 10:06 PM
ERKK's Avatar
how much would you want for them and how are the rings or would they need new ones
Old Sep 15, 2008 | 07:41 AM
ERKK's Avatar
bumpp how much bro
Old Sep 15, 2008 | 05:39 PM
Default Re: (ERKK)
you will need new rings. 15+shipping and they are yours. i have pics here.
https://honda-tech.com/zerothread?id=2370283
Old Sep 15, 2008 | 06:06 PM
ERKK's Avatar
email me ur paypal account to T344183x1 @aol.com and ill send u my address and evrything
Old Sep 15, 2008 | 09:05 PM
ERKK's Avatar
bumppp send me ur name bro i need these asap lol
Old Sep 16, 2008 | 07:44 AM
ERKK's Avatar
BUMP comeon bro send that info lol
Old Sep 16, 2008 | 09:02 AM
dirtygsr99's Avatar
im glad i found this it answered my question
Old Sep 16, 2008 | 09:06 AM
ERKK's Avatar
well thats good and i really wish 91 would send me his info so i can finish my car
Old Sep 18, 2008 | 07:11 AM
Default Re: (ERKK)
i really wish you would pay me so i can send you those pistons so you can finish your car....
Old Sep 18, 2008 | 07:02 PM
AK_CRX's Avatar
Default Re: (91_shoebox_Si)
To answer your og question... A6 block w/z6 head, w/ z6 pistons = bastard z6... on paper, all measurements would be same as a stock z6, including compression ratio. and yes rods are same length in the motor, as is deck height.
The opposite used to be an all motor d series trend... throwing a6 pistons in a z6 to raise compression a [pejorative] hair.
If I'm taking the time to tear my motor apart to do new pistons it better be more than .2 compression of a difference to be worth it IMO.
Old Sep 18, 2008 | 10:22 PM
ERKK's Avatar
what rings would i need to buy?
Old Sep 19, 2008 | 12:01 AM
AK_CRX's Avatar
Default Re: (ERKK)
match rings to pistons
Old Sep 19, 2008 | 10:34 AM
ERKK's Avatar
what do u mean
like since im using an a6 block i should get a6 rings or do u mean since there z6 pistons i need those rings?
