Tranny problems?
Old Sep 13, 2008 | 06:00 PM
ej1252's Avatar
Default Tranny problems?
My car can't go into gear when i'm cruising, but when i'm parked and in neutral, it can go into gear.
What could be the problem?
LS tranny onto b16 block
Old Sep 13, 2008 | 06:09 PM
slomofo's Avatar
GDD Member
If you rev match it, can you upshift? Does it grind at all when putting it into gear from neutral?
Old Sep 13, 2008 | 06:14 PM
ej1252's Avatar
Default Re: (slomofo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slomofo &raquo;</TD></TR><TR><TD CLASS="quote">If you rev match it, can you upshift? Does it grind at all when putting it into gear from neutral? </TD></TR></TABLE>
i dont know wat u mean by rev match
it doesn grind wen i try to put it into gear, like wen the car is off it can go into gear but when the car is on it cant go into gear and it doesn grind or anythin wen i try
Old Sep 13, 2008 | 06:20 PM
infumis's Avatar
rev match is reving the engine to what the rpm would be when you go into a gear.
is there a gear it wont go into or can you not get the car moving at all...?
Old Sep 13, 2008 | 06:23 PM
ej1252's Avatar
Default Re: (infumis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by infumis &raquo;</TD></TR><TR><TD CLASS="quote">rev match is reving the engine to what the rpm would be when you go into a gear.
it cant go into all the gears at all only when the cars off n parked
Old Sep 18, 2008 | 09:18 PM
infumis's Avatar
check you master cylinder for leaks all the way to the slave, check your fluid level if its a hydro tranny. if its a cable, check your pedal and fork to see if the cable is connected
Old Sep 18, 2008 | 09:23 PM
infumis's Avatar
also did you just put this motor in? check your passenger side axel to make sure its all the way pushed into the diff. im guessing this isnt a lsd'ed tranny so if its not pushed in all the way it will take the easiest route which would be no resistance.
shawn_crx
Jun 29, 2005 11:18 AM
TurboTagTeam
Oct 18, 2004 09:01 AM
ComingSoonNearYou
13
May 23, 2004 05:12 PM
Jake
13
Mar 11, 2004 11:33 AM
YelLowITR
Apr 22, 2003 04:17 PM
