WTB: EF Parts...Center Radio / HVAC Stack, Center Dash Vents with Clock, and Drivers Interior Door P
I bought an clean 89 Hatch that was broken into (prior to my purchase). I finally picked it up and the drivers door lock was popped in to get access to the car and the radio was stolen - pryed out with a screwdriver damaging the stack that holds the radio in and the center vents were also damaged.
I'm also looking for a good condition interior drivers door panel as the one in the car has several wear spots. Thanks.
I'm interested but only if it will work on a Hatchback - same console / fitment? My car is a DX so not sure if it has the wire for the clock as the current are is a blank plate. I've yet to pull it out to inspect if there is wiring back there for it.
I need this for those who need to see a picture.
Center Console Vent and surround (as pictured above)
Part Number 5 - Radio Surround (black)
Part Number 8 - Drivers Side Door Lock Cylinder
Part Number 17 - Drivers side door protector
Part Number 2 - Door Sash (the black long vertical trim piece that goes on door next to window above the handle) - it's about 1' 6" long. The upper mounting screw is broken.
Also found I need an antenna.
Modified by jaje at 10:40 AM 9/15/2008
draneusmc
Jan 14, 2005 07:04 PM
zcivicz
Feb 10, 2003 10:58 PM
