ITR / EK4 tranny differences?
Old Sep 13, 2008 | 03:56 PM
user 20082082's Avatar
Default ITR / EK4 tranny differences?
The transmission on my 98 UK ITR is shot. I have found a race gearkit for an EK4 and wondering if it will drop in and what possible compatibility problems i might have.
Any help gratefully received.
Thanks.
Old Sep 13, 2008 | 04:32 PM
eg6ajk's Avatar
Default Re: ITR / EK4 tranny differences? (Tim Radley)
Cases are identical. Gears can be interchanged with exception of 1st gear on some cars (98+ 4.785 FD ITR) which is related to countershaft and final drive kit which must match your differential setup. EG/EK differential can have different bolt pattern and spacing, especially if equipped with LSD.
check it out:
http://www.teammfactory.com/pr...Gears
Old Sep 14, 2008 | 01:02 PM
Default Re: ITR / EK4 tranny differences? (eg6ajk)
Thanks for the reply.
So it sounds like it should drop in but i may have to ditch the stock lsd for a different bolt pattern one then if i am understanding correctly?
Old Sep 14, 2008 | 03:44 PM
eg6ajk's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tim Radley &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for the reply.
So it sounds like it should drop in but i may have to ditch the stock lsd for a different bolt pattern one then if i am understanding correctly?</TD></TR></TABLE>
if you're swapping gears 3-5th then you can retain everything else. If you want to use a EK4 diff then you need to keep EK counter shaft/final drive, and 1st gear.
Old Sep 15, 2008 | 09:13 AM
CW-ITR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6ajk &raquo;</TD></TR><TR><TD CLASS="quote">
if you're swapping gears 3-5th then you can retain everything else. If you want to use a EK4 diff then you need to keep EK counter shaft/final drive, and 1st gear. </TD></TR></TABLE>WOW! Such a great knowledge you have there on Tranny
stockegsix
Sep 14, 2004 01:38 AM
Green94GSR
Dec 25, 2003 06:52 PM
dc2lun
Dec 17, 2003 06:09 AM
bearboy80
28
Sep 9, 2003 09:01 PM
