92 external coil accord
Old Sep 13, 2008 | 03:51 PM
skunk2b18's Avatar
Default 92 external coil accord
it a 92 accord lx, girl let home and called a sec later saying the car shut down on her. I replaced the coil with a new one and do not get spark from it out of the end where the plug goes. My questions are, do the coil and igniter work together to create a spark? would you get spark from the coil with a bad igniter? As of right now there is no spark at the plugs or external coil... igniter is an oki unit... please lmk your thoughts
Old Sep 13, 2008 | 04:35 PM
GhostAccord's Avatar
Default Re: 92 external coil accord (skunk2b18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunk2b18 &raquo;</TD></TR><TR><TD CLASS="quote">do the coil and igniter work together to create a spark?</TD></TR></TABLE>
Yes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunk2b18 &raquo;</TD></TR><TR><TD CLASS="quote">would you get spark from the coil with a bad igniter?</TD></TR></TABLE>
No. The Ignition Control Module (aka igniter) is required to send a signal to the coil in order for it to send voltage to the distributor cap / spark plugs.
My thoughts are to test the ICM (igniter)
Old Sep 14, 2008 | 11:16 AM
skunk2b18's Avatar
Default Re: 92 external coil accord (GhostAccord)
thanks so much bro...
michaelb15
Dec 6, 2012 01:42 PM
kenwolf
Nov 21, 2010 02:06 PM
Accord93SE
Jun 30, 2006 08:12 PM
roc
May 3, 2005 12:56 AM
Michalob234
Dec 29, 2003 06:48 PM
