High RPM engine cut...?
Old Sep 13, 2008 | 03:05 PM
square_1's Avatar
Default High RPM engine cut...?
If I am pushing my 03 Si hard in 2nd or 3rd gear once it gets to about 4500-5500 (never really pay attention to figure out exactly when) I feel the engine kind of cut for just a second and then keep going. Almost as if it hits a dead spot in fuel or something? Anyone have any idea? I thought at first maybe my clutch would slip but the RPMs don't jump up so I know it isn't that. It just stutters for a fraction of a second and then pulls hard again.
THanks guys.
Old Sep 13, 2008 | 08:26 PM
kobeballer96's Avatar
Default Re: High RPM engine cut...? (square_1)
omg i have this same problem. its really not noticable but i though my clutch was slipping aswell. could it be like something like s fuel cut??? lol i dont kno how to fix it. it makes me mad lol
Old Sep 13, 2008 | 11:43 PM
slowman's Avatar
I took way too long
Default Re: High RPM engine cut...? (kobeballer96)
I would probably start with changing plugs. then maybe check fueling (filter/pump).
Old Sep 16, 2008 | 01:05 PM
EMC 3000gt's Avatar
Plugs and wires.
Old Sep 16, 2008 | 01:43 PM
WhiteOnRice's Avatar
Default Re: (EMC 3000gt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EMC 3000gt &raquo;</TD></TR><TR><TD CLASS="quote">Plugs and wires.</TD></TR></TABLE>
Gonna give you a break because you're new to the k-series. (k-series uses coil packs)
Before replacing anything (before guess work), read the plugs.
Old Sep 16, 2008 | 04:52 PM
uncledan's Avatar
Could it be vtec kicking in?
uncledan
Old Sep 16, 2008 | 06:22 PM
square_1's Avatar
Default Re: High RPM engine cut...? (uncledan)
I do have 60K on the original plugs but they seem fine and it does it at the same RPM every time. But it doesn't do it all the time. If that makes sense. I know that Iridium plugs should last like 100K but that is all depending on driving conditions. I think I am going to start with fuel filter and plugs. I'll let you guys know!
Old Sep 16, 2008 | 11:21 PM
slowman's Avatar
I took way too long
Jesus christ dude 60K on original plugs? I'd change that ****. I like to practice the rule: change plugs after every other oil change. That way I know everythings in great shape. Get those plugs out ASAP
Old Sep 17, 2008 | 05:56 AM
blueshark123's Avatar
Default Re: High RPM engine cut...? (slowmanEK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by uncledan &raquo;</TD></TR><TR><TD CLASS="quote">Could it be vtec kicking in?
uncledan</TD></TR></TABLE>
"Vtec" kicks in at 2200 rpm in a k20a3.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by square_1 &raquo;</TD></TR><TR><TD CLASS="quote">I do have 60K on the original plugs but they seem fine and it does it at the same RPM every time. But it doesn't do it all the time. If that makes sense. I know that Iridium plugs should last like 100K but that is all depending on driving conditions. I think I am going to start with fuel filter and plugs. I'll let you guys know!</TD></TR></TABLE>
Fuel filter is fine. Change your plugs. You do know where it is right?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowmanEK &raquo;</TD></TR><TR><TD CLASS="quote">Jesus christ dude 60K on original plugs? I'd change that ****. I like to practice the rule: change plugs after every other oil change. That way I know everythings in great shape. Get those plugs out ASAP </TD></TR></TABLE>
Every other oil change is excessive unless you are beyond the average i/rh/e kpro combo.
Old Sep 17, 2008 | 06:05 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowmanEK &raquo;</TD></TR><TR><TD CLASS="quote">I like to practice the rule: change plugs after every other oil change. </TD></TR></TABLE>
Waaaay too often on iridium plugs. On a side note, I WTB all your used plugs that were only used for two oil change intervals.
Old Sep 17, 2008 | 04:43 PM
square_1's Avatar
Default Re: High RPM engine cut...? (WhiteOnRice)
At 15 bucks a plug I am not changing those suckers every other oil change! Maybe I'll shoot for some plugs and better my already banging 30 MPGs when driving nice!
Old Sep 17, 2008 | 04:47 PM
EG6 Poe's Avatar
did you check your vtec fluid????
Old Sep 18, 2008 | 01:05 AM
slowman's Avatar
I took way too long
Default Re: High RPM engine cut...? (EG6 Poe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG6 Poe &raquo;</TD></TR><TR><TD CLASS="quote">did you check your vtec fluid???? </TD></TR></TABLE>
oil?
Old Sep 19, 2008 | 09:27 AM
oil? </TD></TR></TABLE>
lmao haha oil? u mean
Old Sep 19, 2008 | 12:45 PM
SlimDC5's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowmanEK &raquo;</TD></TR><TR><TD CLASS="quote">Jesus christ dude 60K on original plugs? I'd change that ****. I like to practice the rule: change plugs after every other oil change. That way I know everythings in great shape. Get those plugs out ASAP </TD></TR></TABLE>The plugs are good for 100k. You are changing yours WAY too often
Old Sep 19, 2008 | 12:57 PM
Did you read your plugs yet square_1???
Old Sep 19, 2008 | 04:41 PM
alex02s's Avatar
hey i have an rsx i have kpro and occasionally get lean cut but its from kpro as protection. gl with it man also it might be the plugs because when i was tuning one day my car did something similar to that i changed the plugs and everything was fine
Old Sep 20, 2008 | 07:36 AM
square_1's Avatar
Default Re: (alex02s)
I checked the plugs a couple of months ago and they still looked great. I will check them again. I just wanna be sure it is those before I drop all that money on them.
YA MEEN?
4drint3gr4
Mar 8, 2017 04:53 PM
sk8shorty012
Aug 5, 2007 02:29 PM
Wannabe JDM
Jul 16, 2006 03:44 PM
buckfittyone
Jul 20, 2002 01:45 PM
ActiveAero
Nov 17, 2001 10:08 PM
