Gas pedal help after auto to manual swap!
Old Sep 13, 2008 | 02:06 PM
alscrx's Avatar
Default Gas pedal help after auto to manual swap!
Ok so i was working on a 90 crx DX and it was auto. I installed the b16 swap and did the manual pedals which bolted in perfect!
Now when i went to install the ITR cable and bracket i noticed it had a white circle and a round silver circle on the end that attached to the pedal.
Now the old auto crx and the NEW 5 speed pedals i just installed don't use that type of throttle cable! They use the silver peg .....like on the Throttle body but on both ends.
I tried using the old DX throttle cable on the b16 but it didn't work out. So if i swap just the gas pedals from another car that uses the round circle on the end would that do the trick???
What crx's or civic's use that type of gas pedal???
Modified by alscrx at 6:15 PM 9/13/2008
Old Sep 13, 2008 | 09:10 PM
Dc4iNtEgRa's Avatar
Is Partying at your House
Default Re: Gas pedal help after auto to manual swap! (alscrx)
you need a cable from a 90-93 integra, not a 97-01 type-r.
Old Sep 13, 2008 | 11:36 PM
D16SiHatch's Avatar
Default Re: Gas pedal help after auto to manual swap! (Dc4iNtEgRa)
yep, he is correct ^
Old Sep 14, 2008 | 04:58 PM
alscrx's Avatar
Default Re: Gas pedal help after auto to manual swap! (D16SiHatch)
The 90-93 DA has the same end on the throttle cable as the typr R.
I am using one now on my car......also i don't like the DA cause their is slack in the cable that you can't remove because you run out of adjustment room.
Dukie432
Feb 18, 2009 12:54 PM
gsxr1k05
11
Oct 4, 2007 04:19 PM
zx9rbart
Nov 7, 2006 09:27 AM
KimChiKid
Oct 8, 2006 07:26 PM
cpizzy
Dec 18, 2003 11:16 PM
