timing belt slack
Old Sep 13, 2008 | 01:31 PM
See Are X's Avatar
Default timing belt slack
How much slack is allowable for a b-series timing belt before needing to replace or tighten?
Right now, after turning the crank to tighten the exhaust side of the timing belt, the intake side has between 1/4"-1/2" of play. Is that too loose? The motor is not running right now so I can't tell if it flops around while its on.
Old Sep 13, 2008 | 03:28 PM
civic95hbvtec's Avatar
check the front side of the motor, should be 1 inch play or less in the t-belt.
Old Sep 13, 2008 | 03:55 PM
steven_highet's Avatar
Default Re: (civic95hbvtec)
that is going to be fine. 1/2 is norm dont worry about it. get the motor running and check it then. the only way it will be more is if your block or head has been machined!
Rost
Jul 3, 2009 09:51 PM
stevenDAtegra
May 7, 2009 09:56 PM
corkss
Sep 13, 2008 09:51 AM
melvin
Dec 13, 2005 10:33 PM
johnzm
Jun 16, 2002 06:56 PM
