oem cd player into 92-95 civic
can i use any honda single din cd player in my civic? can i just plug it right in? if not all will fit, then what cd player can i use? thank-you
yeah you can, just make sure that you have the security code so when you hook it up, you can use it. btw, if you dont get the deck for that generation, then the harness won't match up. good luck
No, you can not, not without mods anyway.
Most Honda/Acura single din HUs up to 97-98 will be plug and play, even some Integra's up to 03.
92-95 Honda Civic used the "rear support bracket" mounting system, so a HU using the same mounting system would be the easiest to install.
Newer Honda/Acura use the diff. mounting systems with "ISO", [screws through brackets into sides of HU] being the most common.
The plug change in 97-98 is easily overcome with widely available adapter plugs.
Mounting a non "rear support bracket" HU, although not impossible, will require some custom work.
The face plate trim on the stock 92-95 HU is also a little diff. then the other single din HUs, but really only an issue when trying to install one in other then the 92-95 Civic.
Best bet is to find a CD HU from a late model Integra and if the plug is diff., get the adapter at your local car audio shop.
94
94
cxSHOE
Audio / Security / Video
Mar 3, 2004 09:06 AM
Todd00
May 29, 2001 11:43 PM
