oil leak in spark plug hole
is it safe to pull out the spark plug with oil in the hole . will it risk oil getting inside the combustion chamber? already change all gaskets and grommets. could there be any other reason for the leak?
No, I only changed the spark plug seals, the grommets, and valve cover gasket. But will it be a really bad idea to put out the spark plugs with oil in it and risk getting oil into the combustion chamber?
You could blow compressed air in there and put a rag over the top to catch it. If a little oil gets in there you'll be fine. You're car will be blowing out blue smoke for a little bit though.
premo_si
Jan 23, 2008 08:57 PM
JDM-EJ1
15
Nov 17, 2004 05:32 PM
