No fire on obdo b16 sir
I just swapped a jdm b16 sir into my 90 dx hatch. It had a mpfi swap into it and so obviously i had 2 do the same with the b16. Im thinkin they sent me a shitty distributor with the swap b/c i have switched out the coil pack on it and still no fire. wires are all good and i have checked everything. If you have ne advise please help, thank you!!!
Double check wires @ distributor. When I did the mpfi conversion I accidently swapped the 2 white wires and was going crazy trying to find the problem.
Double and triple check the wiring.
You did use the Dx engine harness correct?
90crxdxb16
Oct 31, 2007 10:47 AM
sytema
Aug 18, 2003 07:06 PM
KevronsEG
Nov 21, 2001 07:37 AM
lol, i searched and searched under the hood and there was a lose wire at the resistor.
