oil catch can question...
Old Jul 25, 2002 | 12:53 PM
GQ Cowboy's Avatar
Default oil catch can question...
can someone explain why to put steel wool inside the oil catch can, I wanted to know what is it supposed to filter? What would be harmful? Thanks for the help.
here is a link to another post showing how to put steel wool into the oil catch can;
https://honda-tech.com/zerothread?id=237087
Old Jul 25, 2002 | 01:10 PM
kinesistech's Avatar
Default Re: oil catch can question... (GQ Cowboy)
Oil catch cans remove oil mist from the air thats moving inside the engine, around the crank and rods. The steel wool is supposed to collect the oil from the air, and put them both were they need to be.
Old Jul 25, 2002 | 03:22 PM
bmm89's Avatar
more surface area where oil vapor can recondense(more cooling area)
Old Jul 25, 2002 | 04:14 PM
GQ Cowboy's Avatar
Default Re: oil catch can question... (kinesistech)
so, its basically a good idea to install steel wool into the oil catch can, correct? This will not hurt anything either correct? Thanks for the help people.
Old Jul 25, 2002 | 05:17 PM
GruvyTune's Avatar
New User
i put in copper Choreboy in my Greddy catch can.
Old Jul 25, 2002 | 05:19 PM
StyleTEG's Avatar
Default Re: oil catch can question... (GruvyTune)
It depends on the catch can.. the SSR unit isn't baffled internally so it needs something to filter out the oil vapors as they flow through the can.
If the catch can is baffled internally, it will already do this with out the use of steel wool.
Old Aug 9, 2002 | 01:02 AM
Project X's Avatar
What grade of steel wool do you use? There are from very fine to coarse. Will the vacuum be strong enough to suck the steel wool bits through the tube into the engine?
Old Aug 9, 2002 | 01:53 AM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Default Re: oil catch can question... (Project X)
don't sweat on the steel wool thikness, just get some non oxidizing material (copper, SS) and go with it.
stan
Old Aug 9, 2002 | 11:37 AM
WOTTEG's Avatar
Be wary if you have your catch can connected to drain directly back into the block. I'm not sure how long steel wool will remain intact before it begins to drain in small pieces with the oil.
(I'm just being cautious.)
Old Aug 9, 2002 | 09:08 PM
b20civic's Avatar
Default Re: oil catch can question... (WOTTEG)
yah, i found that if you have steelwool inside the can and it drains back into the block, that it fills up super quick. If it drains back into the block, it needs to be able to flow pretty good, so steelwool hurts it. Ive got the moroso catchcan.
Old Aug 9, 2002 | 09:36 PM
R_yd's Avatar
Default Re: oil catch can question... (b20civic)
i have moroso can as well...
Old Aug 9, 2002 | 11:33 PM
supergreenNA1's Avatar
New User
why not just put steel wool in the factory catch can??
the only reasons i can see to use an aftermarket catch can are-
1. they look cool
2. to vent the oil vapors to the atmosphere.
Old Aug 11, 2002 | 12:08 AM
tinkerbell's Avatar
Default Re: oil catch can question... (supergreenSol)
1. they look cool
3. because the b20vtec needs one.
mrlegoman
Aug 4, 2009 10:03 AM
rayzian
16
Aug 17, 2007 06:48 AM
Babakarab
Jun 30, 2006 08:30 PM
AMG
44
Aug 17, 2004 08:11 AM
RAS Motorsports
Jul 8, 2003 06:43 PM
