simple parts for 91 ef si
Old Sep 12, 2008 | 10:39 PM
aalba86's Avatar
Default simple parts for 91 ef si
i am hard at work looking for the spare tire cover for a crx... not the carpet... not the trunk cover... that cardboard piece that goes over the spare tire well... i know it must be hard to find, but does anyone know, of maybe the supplies i need to make one? or of a aftermarket retailer? i know its nothing JDM or performance wise, but i am going for a completely clean look
Old Sep 13, 2008 | 04:23 AM
SETI20's Avatar
The EDM one is a plastic honey comb board.
Go to any big hardware store, and they will have a similar type of material. Hell, even 8mm thick dense particle board works. (don't forget to impregnate with moisture sealant tho)
Old Sep 13, 2008 | 07:21 AM
HondaHeddie's Avatar
Default Re: (SETI20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SETI20 &raquo;</TD></TR><TR><TD CLASS="quote">The EDM one is a plastic honey comb board.
Go to any big hardware store, and they will have a similar type of material. Hell, even 8mm thick dense particle board works. (don't forget to impregnate with moisture sealant tho)</TD></TR></TABLE>
my usdm dx has that too
white plastic corrugated sheet
looks just like a slice of cardboard box, but it is milk jug colored plastic not paper
Old Sep 13, 2008 | 09:30 AM
SETI20's Avatar
Weird. Ours are black. Looks like a rock solid sheet of bubble-wrap, only smooth.
Old Sep 13, 2008 | 09:42 AM
zrickety's Avatar
my usdm is the same, black honeycomb like. check the junkyards or make one. i'll send you pics if you go that route
Old Sep 14, 2008 | 02:27 PM
aalba86's Avatar
Default Re: (zrickety)
sure thing, anything to get me started on that... n i was lucky enough to find a greddy manifold 4-2-1 over this weekend installing it later today. now... should i keep the same size exhaust piping?
Old Sep 14, 2008 | 03:28 PM
Vinceg99's Avatar
Default Re: (aalba86)
You mean like this which I have FS in my FS thread
Old Sep 14, 2008 | 04:25 PM
Tippyman's Avatar
Default Re: (Vinceg99)
I cut one out of a peice of thin plywood and then painted it black.
Old Sep 14, 2008 | 04:29 PM
Vinceg99's Avatar
Default Re: (Tippyman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman &raquo;</TD></TR><TR><TD CLASS="quote">I cut one out of a peice of thin plywood and then painted it black. </TD></TR></TABLE>
I did this in my old 85 CRX.
EGKREW
Jun 25, 2008 08:03 PM
agendadjs
22
Dec 3, 2007 03:28 PM
ProSlow07
Feb 4, 2007 03:42 PM
Tim_Robbinz
Jun 8, 2005 09:47 AM
91-lsvtecsi
May 8, 2005 11:00 AM
