LS/Vtec Soon to be tuned.... suggestions needed
Old Sep 12, 2008 | 10:29 PM
SmoothCTR's Avatar
Default LS/Vtec Soon to be tuned.... suggestions needed
So the bottom end on my ctr swap is no longer any good(dont wanna go into it cause it brings back memories). So I had an ls block in my shed which i sent to the machine shop to get hot tanked and honed. Im swapping the block, and my setup is gonna consist of the following....
blox ls/vtec kit
arp rod bolts
arp head studs
acl bearings
p72 polished crank
p72 rods
oem p30 pistons and rings
oem timing belt
oem water pump
stock ctr head
ctr tranny
tri-y small tube header
It will be fully tune on a p28 with crome software
any suggestions will be appreciated. Do i need adjustable cam gears right now? Do I need upgraded injectors or will ctr injectors work fine for now? Should i take a layer off the head gasket?
thanks in advance
Old Sep 12, 2008 | 10:55 PM
chanDAman562's Avatar
Default Re: LS/Vtec Soon to be tuned.... suggestions needed (SmoothCTR)
personally ive build plenty of ls vtec's....i would keep the ls rods cause of the stroke, and your safe with the head gasket and injectors...no need to take the any layers off of it....if your planning on putting some cams in and any other parts that would bring more air flow in then i would recommend injectors 310 or 315 cc should be good!
great setup man!
Old Sep 12, 2008 | 11:10 PM
SmoothCTR's Avatar
Default Re: LS/Vtec Soon to be tuned.... suggestions needed (chanDAman562)
Yea the reason im running the gsr rods is because i was planning on doing ctr pistons and i figured there would be more room for error with p72 assembly. But then i realized i dont wanna daily drive on pct pistons. Well thanks for the input i appreciate it man
Old Sep 13, 2008 | 06:38 PM
yeah no worries man just showing some love man! any questions just let me know!
Old Sep 18, 2008 | 05:21 PM
UncleD's Avatar
Hey Chan, email me - jdm_eg@hotmail.com
To the o.p., has the head been milled?
Old Sep 18, 2008 | 10:27 PM
projectTeG's Avatar
blox has a ls/vtec kit?
Old Sep 19, 2008 | 07:22 AM
SmoothCTR's Avatar
Default Re: LS/Vtec Soon to be tuned.... suggestions needed (clean rice)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clean rice &raquo;</TD></TR><TR><TD CLASS="quote">Hey Chan, email me - jdm_eg@hotmail.com
To the o.p., has the head been milled?</TD></TR></TABLE>
No it has not been milled. Do you think it needs it?
Old Sep 19, 2008 | 07:24 AM
SmoothCTR's Avatar
Default Re: (projectTeG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectTeG &raquo;</TD></TR><TR><TD CLASS="quote">blox has a ls/vtec kit?</TD></TR></TABLE>
yea blox makes one man
Old Sep 19, 2008 | 07:26 AM
projectTeG's Avatar
Default Re: (SmoothCTR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SmoothCTR &raquo;</TD></TR><TR><TD CLASS="quote">
yea blox makes one man</TD></TR></TABLE>
who'd they copy? GE?
good luck on the build just make sure you get the rod refreshed after the arp install, your didnt list that i wasnt sure if your doing it or not. you go with the new wave-loc arps?
keep injectors stock and cam gears
Old Sep 19, 2008 | 08:16 AM
SmoothCTR's Avatar
Yea I got the rods shotpeened and they look brand new. I just got the regular arp's though. Gonna start putting it together today. I got all the parts except for the timing belt and water pump which should be all set after work.
thanks for the advice
Old Sep 19, 2008 | 09:25 AM
projectTeG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SmoothCTR &raquo;</TD></TR><TR><TD CLASS="quote">Yea I got the rods shotpeened and they look brand new. I just got the regular arp's though. Gonna start putting it together today. I got all the parts except for the timing belt and water pump which should be all set after work.
thanks for the advice </TD></TR></TABLE>
i dont mean shot peened, i mean getting the big end of the rod re-sized since installing the arp bolts changes the big end.
Old Sep 19, 2008 | 11:13 AM
SmoothCTR's Avatar
yea when they shotpeened it i had them re-size the ends also
Old Sep 26, 2008 | 03:01 PM
SmoothCTR's Avatar
so for some retarted reason that i still cant explain, i ordered the wrong size headgasket ordered an 84.5mm which i dont need. So if someone needs an 84.5mm brand new blox headgasket for ls-v let me know
Old Sep 27, 2008 | 08:20 AM
wascly's Avatar
It's not an LS/Vtec if you are using a p72 crank...
What makes an LS/Vtec is the increased stroke, not the stamp on the block...
Old Sep 27, 2008 | 08:36 AM
girliehonda's Avatar
agree
Old Sep 27, 2008 | 09:23 AM
IntegraType-R's Avatar
Default Re: (girliehonda)
You do realized you destroked the ls right?
I'm reimplying this because then it defeats the purpose of what your doing.
Old Sep 27, 2008 | 02:25 PM
SmoothCTR's Avatar
Default Re: (IntegraType-R)
see this is what happened.... i had the ctr swap for 3 years now and i had always wanted to stroke it. So i bought gsr crank and rods to use with pct pistons. So then my ctr bottom end blew. I had an ls block, and a polished p72 crank and shotpeened rods the ends resized for arp rod bolts. So i put that together since i already had everything ready to go. so yea your right its not an ls/vtec, it turns out to be a stroked ctr wich is what i wanted in the first place lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraType-R &raquo;</TD></TR><TR><TD CLASS="quote">You do realized you destroked the ls right?
I'm reimplying this because then it defeats the purpose of what your doing.</TD></TR></TABLE>
yes i know its destroked. I didnt do this to do ls/vtec, I did it this way cause thats the parts i had, and since its a daily driver, i didnt have time for anything else
but this thing should still be a pretty good setup right?
Old Sep 27, 2008 | 02:31 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SmoothCTR &raquo;</TD></TR><TR><TD CLASS="quote">see this is what happened.... i had the ctr swap for 3 years now and i had always wanted to stroke it. So i bought gsr crank and rods to use with pct pistons. So then my ctr bottom end blew. I had an ls block, and a polished p72 crank and shotpeened rods the ends resized for arp rod bolts. So i put that together since i already had everything ready to go. so yea your right its not an ls/vtec, it turns out to be a stroked ctr wich is what i wanted in the first place lol
but this thing should still be a pretty good setup right?</TD></TR></TABLE>
PCT/CTR Pistons are CRAP..understand that now, they are not a good piston, they're horrible on the combustion process and to be honest, they'll create more problems then what they help, if they aren't in a b16..
Longer/crank/rods from a gsr, which are longer and create a bigger stroke then the b16b, will then create more problems, specially if you run bigger cams and have to gear tune.
Why not, just save your money, get a cheap ls crank, they're like 100 bucks, ls rods, are really cheap too, and arp rod bolts cheap.. get u some gsr pistons or typer pistons if ur sticking with oem and call it a day.
if you save up, it'll probably take about 300 bucks, to get a ls crank and rods..golden eagle sells ls cranks for around 100 bucks.. you need to search ctr pistons they're completely garbage.. and heavy as ****.
Old Sep 27, 2008 | 02:32 PM
mar778c's Avatar
Community Builder
Community Influencer
Yea, it will be all right. As long as you as it's put together well, it should not have any problems.
Old Sep 27, 2008 | 03:28 PM
SmoothCTR's Avatar
PCT/CTR Pistons are CRAP..understand that now, they are not a good piston, they're horrible on the combustion process and to be honest, they'll create more problems then what they help, if they aren't in a b16..</TD></TR></TABLE>
Im running p30's. i know pct pistons are crap, i wanted to run them a while back until i did my homework and realized all that stuff u mentioned.
Old Sep 27, 2008 | 06:10 PM
Im running p30's. i know pct pistons are crap, i wanted to run them a while back until i did my homework and realized all that stuff u mentioned. </TD></TR></TABLE>
Well on your way then.
Glad your researching as you go, i'd suggest pm Golden Eagle about a true ls crank / rods tho.
Old Sep 29, 2008 | 08:44 AM
SmoothCTR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraType-R &raquo;</TD></TR><TR><TD CLASS="quote">Well on your way then. Glad your researching as you go, i'd suggest pm Golden Eagle about a true ls crank / rods tho.</TD></TR></TABLE>
yea i will most likely do that. im going to be building another ls bottom end for turbo. this one just has to get me to work lol
VTLX 03R
Jan 8, 2014 01:13 PM
ekVic214
16
Sep 5, 2011 01:34 PM
jdm kidd
30
Jan 23, 2009 04:57 PM
BOOSTEDgreeneg
Feb 15, 2006 03:42 AM
90 integra
27
Oct 13, 2004 09:41 AM
