alright got a simple one for ya'll
Old Jul 25, 2002 | 12:38 PM
HatchBox's Avatar
Skoobie no more...
Default alright got a simple one for ya'll
im got a radar detecter and no cig lighter...how would i wire detecter to a switch..do i just cut off the cig plug and run the wires just like any other appliance
Old Jul 25, 2002 | 12:49 PM
kinesistech's Avatar
Default Re: alright got a simple one for ya'll (xxkenyon419xx)
Yes, open up the plug and check what the fuse is rated too, and use one the same size.
Spade's Avatar
make sure you run it for an accessory.....oh and keep in mind that you won't be able to disconnect the dectector when police pull you over.
Old Jul 25, 2002 | 12:52 PM
HatchBox's Avatar
Skoobie no more...
Default Re: alright got a simple one for ya'll (Spade)
anyone got a diagram...i kinda forget how to set that up...
are they illegal in Ny does anyone know??
[Modified by xxkenyon419xx, 1:53 PM 7/25/2002]
nixadm's Avatar
you could wire in a switch
Old Jul 25, 2002 | 04:10 PM
HatchBox's Avatar
Skoobie no more...
Default Re: alright got a simple one for ya'll (nixadm)
do i just cut off the cig plug then....or what
Old Jul 25, 2002 | 05:38 PM
kwil666's Avatar
why would it matter if you had it on when you got pulled over?
keith
Old Jul 25, 2002 | 07:49 PM
HatchBox's Avatar
Skoobie no more...
Default Re: alright got a simple one for ya'll (kwil666)
because there illegal
Old Jul 26, 2002 | 01:16 AM
Not illegal in CA. Cut the plug. Stripp both wires. On the fuse box, there is an ignition power output. Place a wire with an inline fuse from there to the power side of the radar detector. Run the ground wire to the switch and from there to ground.
You can put the switch on the power side if you want, but amps will not flow through it on the ground side.
vi3tromanc3r
Feb 11, 2007 03:41 PM
Shizznaz
Audio / Security / Video
Dec 29, 2004 07:41 AM
fe519
May 17, 2003 11:35 AM
JoshRambo
Jul 20, 2001 03:42 PM
