07 and 08 differences
Red stitching shift boot.
Ambient light that shines down on shifter at night.
Rims may be darker,but I can't tell.
Better transmission(no 3rd gear issue).
No key hole in trunk or pass. front door.
Shift pattern on shift **** is red.
different rear upper control arms (thought i think the 06-07 were upgraded to the newer ones under warranty if you asked them for it). i've also heard that the spring rates were lowered to match the si sedan, but i haven't heard much about that so i dunno if its true.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vladd »</TD></TR><TR><TD CLASS="quote">different rear upper control arms (thought i think the 06-07 were upgraded to the newer ones under warranty if you asked them for it). i've also heard that the spring rates were lowered to match the si sedan, but i haven't heard much about that so i dunno if its true.</TD></TR></TABLE>
wrong. that was only on the regular civics, not the si. it was excluded as stated in the tsb.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by i-VTEC_DOHC »</TD></TR><TR><TD CLASS="quote">
wrong. that was only on the regular civics, not the si. it was excluded as stated in the tsb.</TD></TR></TABLE>
are you saying i'm wrong about the 08 si's having the different arms, or about being able to have your 06-07 arms changed to the 08?
are you saying i'm wrong about the 08 si's having the different arms, or about being able to have your 06-07 arms changed to the 08? </TD></TR></TABLE>
the 06-07 arms.
the 06-07 arms.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. DB2 »</TD></TR><TR><TD CLASS="quote">Red stitching shift boot.
Shift pattern on shift **** is red.</TD></TR></TABLE>
I'd like to see some proof of the Tranny issue.. . I guess I could just ask my buddy whos brother is a engineer for honda though.. .
I will update if I hear anything
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FijiBlueFG2 »</TD></TR><TR><TD CLASS="quote">I've had an 07 and an 08. What is this ambient light you speak of? Transmission is the same. The back of the seats is a different material. </TD></TR></TABLE>
It's the red LED in the sunroof switch panel that provides a soft red glow right above the shifter.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by K5^ »</TD></TR><TR><TD CLASS="quote">
It's the red LED in the sunroof switch panel that provides a soft red glow right above the shifter.</TD></TR></TABLE>
It's amber (or orange).
its the light switch that turns on the dome light if u open the doors
Street Ghost
23
Jan 2, 2004 05:35 PM
