Help me start my car - theft attempt
There was a theft attempt on my car and now the car wont start. I had an alarm installed by the dealer when I first got the car and the thief broke that too. The car would crank, but it wont start all the way. Any tips on where to look?
Ignition on the steering column was taken apart but they couldn't stat it.
Theres not really any pics to show anything. Everything looks the same except the plastic part of the steering column is off along with the left part of the ignition switch is hanging off. The rest are wires underneath the dash.
that left part of the ignition switch is a white peice of plastic right?
on 1 side it has wires, the other side has a small hole.. take a 4 hear screwdriver, stick it in there and try to start the car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 216.226.142.95:27016 »</TD></TR><TR><TD CLASS="quote">Where's the harness located so I can check?</TD></TR></TABLE>
It has the ignition switch on the back side of the key cylinder, held by 2 screws, with several wires running down the steering column, and then 2 plugs going into the fuse box.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 »</TD></TR><TR><TD CLASS="quote">
It has the ignition switch on the back side of the key cylinder, held by 2 screws, with several wires running down the steering column, and then 2 plugs going into the fuse box.</TD></TR></TABLE>
just reading this since hurricane ike hitting my area, still no electricity
is it easy to take off and install and put a new one? almost plug and play?
Chris Benoit
Nov 3, 2004 11:25 AM
