JDM B18C5 in a 5th gen si hatch
From what I have read so far I can't use the JDM engine harness, but I can use the stock si one. Also I have read that you have to use the civic injectors also. Can't I just wire in the connectors of the the JDM harness and run the integra injectors? I will be running a chipped p28 also.
I repeat you can use the JDM wiring harness. I have done this it will work.
). The only thing that I couldnt get to reach was the white wire that goes from the alternator to the fuse box. So I just use the wire out of my cx harness.Also, if you are running a rechipped P28 ecu, you will need a USDM vtec solenoid, because the JDM motor doesnt have the oil pressure switch.
I am running this set up w/ a kenji rechipped P28 and the motor runs strong.
Good luck
alien
Jun 13, 2006 01:36 PM
RedheadRacing
Oct 21, 2002 10:27 PM
