LED signal light blink TOO fast
Ok guys, i just have 1 question, ok i just bought this LED signal bulb
http://cgi.ebay.com/ebaymotors...65650
It fits fine, BUT IT BLINK TOO FAST (3 times normal speed) WHEN I SIGNAL. WHAT CAN I DO TO FIX THAT?
Why did you replace the bulb in the first place? Was it bad? It could be the other bulb either rear or front opposite of the one you replaced is bad making the new blink too fast.
no the old bulbs are not bad, it just that i want to replace the amber bulbs with White LED bulbs. OK, so i'm going to install side marker too. (I"M SO SORRY ABOUT THIS, I"M JUST A NOOB) Ok so How strong the resistor has to be so that my LED signal bulb and side marker blink normal.
As posted above, you'll probably need to play with it, technically you could get a potentiometer and have a variable resistor.
Radioshack + 1kpot = super fast or super slow blinkikng
alright i this PROBLEM IS SOLVED. I found this site that show you exactly what to do step by step. I follow it, and everything blink as normal now. so go here. PLZ give credit to whoever created this site.
http://www.plasmaled.com/tail_...x.htm
W95civicEXcoupe
Mar 5, 2015 02:51 PM
