96 EK hatch with b17a gsr swap, wiring complete, fuel pump not sending fuel.
Old Sep 12, 2008 | 10:30 AM
shandonwall's Avatar
Default 96 EK hatch with b17a gsr swap, wiring complete, fuel pump not sending fuel.
Does anyone know why a civic that was running before a swap would have issues with the fuel pump not turning on after the swap?? The ECU is plugged in, (P72) and is using a rywire obd2a-obd1 conversion harness. all the fuses are good and the main relay clicks when powered. I'm thinking aboutrunning an on/off switch directly to the pump. Help
Old Sep 12, 2008 | 01:23 PM
LA_HONDAS's Avatar
Default Re: 96 EK hatch with b17a gsr swap, wiring complete, fuel pump not sending fuel. (shandonwall)
run a power to the pump and see if it comes on if it do check fuel relay,ecu and the jumper harness
hit the fuel relay it could be bad even if it clicks
Old Sep 14, 2008 | 08:45 AM
Default Re: 96 EK hatch with b17a gsr swap, wiring complete, fuel pump not sending fuel. (LA_HONDAS)
I did the jumper wire trick with the main relay and when i turn the key on, the pump works now.
ksbenjamin44
Jun 25, 2009 05:22 PM
srt4pilot
Jun 3, 2009 10:20 PM
zippakilla
Feb 6, 2009 04:01 AM
civic2liters
Jun 1, 2008 08:11 PM
