EF 88-91 JDM LCA's
Old Sep 12, 2008 | 07:56 AM
jdm4drSi's Avatar
Banned
Default EF 88-91 JDM LCA's
Ok, open discussion, what LCA's are available from the JDM motherland specifically ... or .. can fit the EF?
Old Sep 12, 2008 | 08:35 AM
SETI20's Avatar
Rear LCA's are the same fitment as any ED/EE/EF. Even tho on the EDM VT and JDM SiR they are visually different. They are interchangeable.
With the front you have no options that I know of. Altho I have seen pictures of custom aluminum CNC'd arms (similar to function 7 design), those were a one-off project.
Old Sep 12, 2008 | 09:42 AM
jdm4drSi's Avatar
Banned
What about known JDM manufacturers of LCA's for the EF?
SSR is a South East Asian company, right? Humm, I know the SSR EG LCA's fit the EF, it's been done before.. any other input?
Thanks for the reply!
Old Sep 12, 2008 | 12:59 PM
SETI20's Avatar
EF and EG rear LCA's are indeed interchangeable. But that depends on the swaybar application.
Be very careful. Some of the LCA's are shorter. They claim to "fix" camber issue. But all they do is change the tracking width of the rear suspension. But not the front. Good luck having your car aligned after that.
Old Sep 12, 2008 | 08:58 PM
Crx Jimmy's Avatar
Default Re: (jdm4drSi)
ssr makes wheels I think you mean srr (super road race) they make lower control arms. I have a set with spherical bearings in them
Old Sep 12, 2008 | 11:14 PM
jdm4drSi's Avatar
Banned
Default Re: (Crx Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">ssr makes wheels I think you mean srr (super road race) they make lower control arms. I have a set with spherical bearings in them</TD></TR></TABLE>
Thanks for the correction, I always confuse them. how is the EG LCA fitment into an EF?
Old Sep 13, 2008 | 01:23 AM
SETI20's Avatar
Read. I pointed that out several posts ago.
Old Sep 13, 2008 | 08:54 AM
jdm4drSi's Avatar
Banned
Default Re: (SETI20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SETI20 &raquo;</TD></TR><TR><TD CLASS="quote">Read. I pointed that out several posts ago.</TD></TR></TABLE>
I was referring to the SRR's, since you said the LCA's may vary in size due to "camber correction".
Old Sep 13, 2008 | 09:28 AM
SETI20's Avatar
EG and ED/EE/EF arms are the same. They have different types. So the problem is with the arms, and not the car they are going on.
However, not all cars have rear sway bars, or mounting points in the same location. So that needs some attention. But still not any problem to modify with minimal effort.
Old Sep 13, 2008 | 10:32 AM
jdm4drSi's Avatar
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SETI20 &raquo;</TD></TR><TR><TD CLASS="quote">EG and ED/EE/EF arms are the same. They have different types. So the problem is with the arms, and not the car they are going on.
However, not all cars have rear sway bars, or mounting points in the same location. So that needs some attention. But still not any problem to modify with minimal effort.</TD></TR></TABLE>
Yeah, the sway bar is an issue if it does mount to the LCA itself. Of course, the ST swaybars mount on their on bracket on the shock, so... that wont be an issue.
Is SRR Malaysian?
Old Sep 13, 2008 | 12:06 PM
EFSedan#6's Avatar
I dont see how the "JDM" versions of the LCA's would be any different than the USDM ones. I mean it is stock. Lame ****. Go aftermarket.
I am gonna rock these in a few weeks.
Old Sep 13, 2008 | 12:07 PM
jdm4drSi's Avatar
Banned
Default Re: (EFSedan#6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFSedan#6 &raquo;</TD></TR><TR><TD CLASS="quote">I dont see how the "JDM" versions of the LCA's would be any different than the USDM ones. I mean it is stock. Lame ****. Go aftermarket.
I'm already rocking the F7's...
diegospecaccord
Jan 23, 2006 03:45 AM
b16crx1
Jun 6, 2004 02:22 PM
