B16a VS GSR Tranny
Old Sep 12, 2008 | 07:02 AM
b20beast83's Avatar
Default B16a VS GSR Tranny
I have a b16a, bolt ons.
I have a b16a gearbox, i want to switch to a gsr tranny.
How much slower would i be if any difference at all, due to the gsr taller ratios.
Old Sep 12, 2008 | 07:22 AM
LastGenEK's Avatar
Default Re: B16a VS GSR Tranny (b20beast83)
I recently went from a gsr tranny to a Type R trans (B16a ratios) and its faster for sure but Im wanting to put the gsr back in
Id go GSR But im also running A turbo GSR motor 262whp.... It seems with the type r trans im shifting into 5th alot... the gsr 4th is pretty solid gear
Old Sep 12, 2008 | 05:04 PM
2LEM1's Avatar
I like to party
Community Builder
Community Influencer
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20beast83 &raquo;</TD></TR><TR><TD CLASS="quote">
How much slower would i be if any difference at all, due to the gsr taller ratios.</TD></TR></TABLE>
As long as you don't fall out of VTEC when you shift it really won't make a huge difference. Obviously higher gears are faster (barring shift points, track length, traction, etc) but going from the b16 to the gsr won't change much other than your gas milage.
Old Sep 12, 2008 | 05:55 PM
racebucket_eg's Avatar
Default Re: B16a VS GSR Tranny (2LEM1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2LEM1 &raquo;</TD></TR><TR><TD CLASS="quote">
As long as you don't fall out of VTEC when you shift it really won't make a huge difference. Obviously higher gears are faster (barring shift points, track length, traction, etc) but going from the b16 to the gsr won't change much other than your gas milage. </TD></TR></TABLE>
He will fall out of vtec, in my opinion it's a horrible idea. A tourqeless B16 and adding taller gears is not a good combination.
Just a side note to the OP I picked up 3 tenths in the 1/8 by switching out my GSR granny for a B16.
viejohombre
May 24, 2010 01:43 PM
b18c4door
Feb 2, 2007 04:43 PM
BigIslandBoi
Jan 18, 2004 08:01 PM
zer0.
Nov 4, 2003 02:08 PM
AzN_Flava
Apr 11, 2003 06:57 PM
