Hummy noise concern ?? help
Old Sep 11, 2008 | 06:23 PM
Haccord1996's Avatar
Default Hummy noise concern ?? help
Hey guys i recently did my timing belt on my 96 accord including the balancer belt and tensioner after that my car has a lil hummy noise at low rpms when driving. first started at idle thought ive mightve had the belt tight so i adjusted again and now makes it till bout 2k rpms then goes away but then hear it again when slowing down any clue?????? need help
Old Sep 12, 2008 | 04:21 PM
Default Re: Hummy noise concern ?? help (Haccord1996)
Can anyone help?????
Old Sep 12, 2008 | 06:41 PM
gqstatus05's Avatar
Humming noise while driving. It could be your bearings. If it is that and you are tech saavy. I would park your car in your driveway, remove the wheel and just bring both knuckles to your mechanic and have him install the bearing on the knuckle instead of bringing the whole car. You'll save alot of money and they may only charge you $25 dollars for each side.
Also check to see if the Timing Belt is shredding on the sides. All I can think of now.
I live in hackensack, if you want you could come down to my town and I can check it out for you and help you take it apart.
PM me if anything.
Old Sep 13, 2008 | 05:03 AM
Default Re: Hummy noise concern ?? help (gqstatus05)
Thanks it definely timing belt problem thanks man I am a tech at maywood mitsubishi thanks alot
patrickvertigo
33
Sep 19, 2010 06:20 PM
Nutcase4life
Oct 24, 2007 10:48 AM
ceehris
Dec 13, 2006 10:10 AM
VTEC-LUDE
Jun 1, 2006 05:14 AM
94gsr_vtc
Nov 24, 2004 03:45 PM
