tie rod movement... with video. got question..
Old Sep 11, 2008 | 02:55 PM
project-boosteD's Avatar
Default tie rod movement... with video. got question..
what do i do about this issue, i dont care about the boot being torn, dont drive it enough to care. what do i do about the movement, innner rod, outer rod, rack and pinion?.... what do i dooooo???
http://www.youtube.com/watch?v=ldbotqwjtpA
Old Sep 11, 2008 | 03:35 PM
PogKai's Avatar
It's the inner tie rod. Nice music in the brackground hehe.
Old Sep 11, 2008 | 07:43 PM
are you positive of this?... anybody have an opinion?
Old Sep 11, 2008 | 08:01 PM
slomofo's Avatar
GDD Member
Just change the inner tie rod, tie rod boot, and get an alignment, what's so difficult about that?
Old Sep 12, 2008 | 05:31 AM
take it easy bro, just makin sure i dont need a whole rack and pinion, no need for the hostility....
Old Sep 12, 2008 | 09:36 AM
anybody have a write up on how to do this?...
Old Sep 12, 2008 | 09:50 AM
slomofo's Avatar
GDD Member
I'll make a write up.
1. Remove wheel.
2. Remove outer tie rod, count the amount of times the tie rod turns as you take it off, then write the amount down somewhere..
3. Remove clamps from inner tie rod boot.
4. Remove inner tie rod boot.
5. Using special tool, remove inner tie rod.
6. Install new inner tie rod. followed by boot.
7. Spin on outer tie rod the same amount of revolutions as you did when you pulled it off.
8. Install new cotter pin and put tire back on.
9. Get in car and drive to alignment shop.
10. Get raped by the alignment guy.
11. Go home crying, but with a perfect alignment.
Old Sep 12, 2008 | 01:28 PM
srmofo's Avatar
Default Re: (slomofo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slomofo &raquo;</TD></TR><TR><TD CLASS="quote">I'll make a write up.
1. Remove wheel.
11. Go home crying, but with a perfect alignment. </TD></TR></TABLE>
thats about all there is to it
Old Sep 12, 2008 | 07:28 PM
awesome... preciate it guys
Old Sep 13, 2008 | 07:30 AM
alright so none of these parts stores around here have this specialty tool needed.... what else can i use??? or any other technique?
Old Sep 13, 2008 | 06:21 PM
postman's Avatar
Default Re: (project-boosteD)
nope need that tool. autozone or advanced usually has a tool rental program
Old Sep 13, 2008 | 09:24 PM
PogKai's Avatar
I use this:
a big one, like 16" in length.
Old Sep 14, 2008 | 09:26 AM
yeah def. just used a wrench that fit.... came right off after the pin broke
bob78cvcc
Honda CR-V & Element
Dec 10, 2012 01:46 PM
skipbudlong
31
May 6, 2010 10:21 AM
msinsky14
50
Apr 21, 2007 03:50 AM
Timmah!!
Jul 21, 2003 03:46 PM
