So i cleaned my iacv
01 ls.bs.140k i had an unusual idle so i cleaned the iac, put it back on and after warm up it idles fine...push the throttle, release throttle rpm dips down to 100 and then up to 500. i tested the valve using direct battery power and its fine.has anyone else had this problem or know anything about this. oh yea i used carb cleaner.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thabao »</TD></TR><TR><TD CLASS="quote">you probably forgot to plug in one of the two lines on the bottom of it</TD></TR></TABLE>
That's what I'm thinking.
Get a manual any generic one from Pepboys it has some troubleshooting steps on there for IAC, IAB i believe. Correct me if I am wrong, but double-check everything, check if that carb cleaner didnt eat the gasket of the component itself. OR take it off it again and take a a clear picture of it. Post it on here.
no cel. everything hooked up the way it came off im mecanically inclined so yea. also there is a screen on the iac that was bubbled out i cleaned it and pushed it in...later got pin punched through and pulled screen back towards me...after i let go of throttle rpm goes to 100 then up to 500 still not the 800 im looking for. also i dont belive that the drastic dip in rpm is normal.
check your tps calibration thingy mabob im pretty sure thats your problem IF your map and tps arent switched and all your plugs are plugged in correctly, and all your sensors are in working order.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kronikSLOW »</TD></TR><TR><TD CLASS="quote">i dont belive i reset it. how do i do that, just unplug negative for 5 minutes?</TD></TR></TABLE>
Pull the ECU fuse.
Pull the ECU fuse.
o ok ill do that. and i didnt disconnect any vacuum lines or map just the iac and the 2 coolant lines. another thing i did was hook up the iac to battery power and it opens..but when i turn car on, engine off it makes noise but no movement is this normal with the engine off.
Takumi Fujiwara
Dec 25, 2005 10:26 AM
