wtt d16z6 for b series swap
Hey guys i am wanting to do a b-series swap (prefer either an LS or possibly a B16). Here is the low down on it and what you will get with it
obd1 d16z6
148-150 compression accross the board
ex transmission (hydro)
you get the full long block with trans intake mani everything
oil changed with mobil 1 synthetic
trans fluid honda mtf only
clutch has alot of meat left on it
around 100,000 on motor
header wont be included.
will get the motor mounts and shift linkage
also everything inside the dizzy has been replaced new ignitor, coil pack, rotor cap, plugs, wires.
timing belt and water pump only have about 200 miles on them.
Here is what i would like to trade for
b18b1 full swap, transmission and mounts
b16 full swap, transmission and mounts
b20 full swap with transmission and mounts.
Please let me know what you have, would prefer to have a straight swap across, can probably even help you put the motor in. Thanks! also the valve cover is still white.
obd1 d16z6
v8destroyer
Jan 24, 2008 05:37 PM
