89 CRX Si burning oil
Old Sep 11, 2008 | 01:55 PM
Snoxxy's Avatar
Default 89 CRX Si burning oil
Whats up everybody,
I just bought a CRX , which burns oil..
I checked compression and it checked awesome, Headgasket was good, so I went ahead and changed the valve seals. I never did it before so it was quite interesting. needless to say, the engine still burns oil. Now, I have 3 ideas as to why it would still burn oil.
1. I just got autozone valve seals.. and they don't do seal as tight as they should
2. I screwed up and didn't do it right ?
3. The problem is somewhere else.
any ideas?
Thanks in advance and I did do a search, but didn't come up with anything.
Phil
Old Sep 11, 2008 | 02:03 PM
TOO MUCH TORQUE's Avatar
are you sure its BURNING oil, maybe it could be LEAKING oil.
If you think its burning, the other thing is your oil control rings. Compression test does not tell you if your oil control rings are messed up, a leak down test will.
Old Sep 11, 2008 | 02:39 PM
Snoxxy's Avatar
im positive it isn't leaking. I parked it in the garage and not a drop of oil came out.
I am sure it is burning oil because of the smoke coming out under accelration.
Old Sep 11, 2008 | 02:43 PM
valve seals usually show smoke when your car is started up if i remember correctly. Does it smoke after its fully warmed up? if so its most likely the control rings. if thats the case, you'll need an engine rebuild
the smoke is light blue right?
Old Sep 11, 2008 | 02:49 PM
Snoxxy's Avatar
yeah smoke is light blue. and I can make it smoke whenever I want, start up or heated up. if I get on it, it smokes.. If I redline 1st and shift into 2nd and look in the rearview mirror, I can see the cloud so .. rings huh ?
Old Sep 11, 2008 | 03:05 PM
yah its most likely the rings..swap in a b series and call it a day
how many miles on the engine?
Old Sep 11, 2008 | 03:08 PM
Snoxxy's Avatar
I was gonna swap a B series regardless, but was gonna use the D-series till i go on my deployment, no biggy I have another car I can drive
and 244531 miles
Old Sep 11, 2008 | 04:35 PM
Johnny-Red's Avatar
Default Re: (Snoxxy)
Mine does the same thing, Quart a week.
I'm just running it till it blows but in the mean time Just laugh at the people stuck in the cloud behind you.
Old Sep 11, 2008 | 05:04 PM
Snoxxy's Avatar
yeah I was considering that
Old Sep 12, 2008 | 06:19 AM
pxsx's Avatar
same thing with my car, yeah its pretty funny, everytime someone is tailgaiting me i make a cloud of smoke for them
Old Sep 12, 2008 | 07:29 AM
Jet805's Avatar
Default Re: 89 CRX Si burning oil (Snoxxy)
stupid question... but what weight of oil are you using? If i use 5 it burns fast if i use 10 it burns maaaayyybe 1/2 to 1qt every oil change.
Old Sep 14, 2008 | 01:19 AM
BAZ's Avatar
BAZ
Default Re: 89 CRX Si burning oil (Jet805)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jet805 &raquo;</TD></TR><TR><TD CLASS="quote">stupid question... but what weight of oil are you using? If i use 5 it burns fast if i use 10 it burns maaaayyybe 1/2 to 1qt every oil change. </TD></TR></TABLE>
x2
SpoonfedCivic
Aug 21, 2011 06:53 AM
serjey15
Dec 4, 2010 07:20 PM
Jeff
Apr 18, 2005 06:23 AM
Sl0wEK
Dec 5, 2004 10:12 PM
98cwitr
Apr 27, 2004 01:34 PM
