FUEL INjector/COmputer problems!!
Old Jul 25, 2002 | 10:38 AM
civicon19s's Avatar
Default FUEL INjector/COmputer problems!!
Here is the situation... i have a supercharged(jackson) JDM b16a2(obd1) in my 97 hatch. Right now it is running on 3 cylinders because the #1injector is NOT working. I switched the injectors around so i KNOW thats not the problem. I checked my wiring with my volt meter and the results were::: All the working injectors fluxuate between 1-2volts whereas the #1 stays at a steady 13-14volts. What is up with this?? Is it possible its an ECU problem?? ADVice PLEASE! Thanx
Old Jul 25, 2002 | 10:48 AM
Spade's Avatar
Default Re: FUEL INjector/COmputer problems!! (civicon19s)
I would look for frayed wires before trouble shooting the ECU.
Old Jul 25, 2002 | 11:35 AM
civicon19s's Avatar
Default Re: FUEL INjector/COmputer problems!! (Spade)
Hey, ALL the wiring is basically stock with the exception being where i spliced on the OBD1 injector clips! Ive of course already checked that.. what is going on with this??
Old Jul 25, 2002 | 11:39 AM
Spade's Avatar
I would investigate your harness and see if anything slipped.
Old Jul 25, 2002 | 12:04 PM
civicon19s's Avatar
Hey i of course did THAT too...the only thing that COULD have slipped and cause this problem is the injector 1 pin and ive checked that! ive determined that the yellow/black wire on the clip is givving the right voltage(consistent with the others..about 13volts) and the brwn wire is the signal wire from the ECU. Ive tested the system by running a fake brwn wire STRAIGHT from the ecu, to the injector clip and this STILL didnt solve my problem... what u think?
Old Jul 25, 2002 | 12:07 PM
Spade's Avatar
Yesh, well, can you find someone to borrow an ECU from?
lsvtek
15
Jul 10, 2012 02:28 PM
chrysanderson
14
Nov 7, 2010 09:08 PM
hatchaneg
Aug 21, 2010 10:42 AM
HamiltonRex
19
Jul 10, 2004 01:05 PM
SC94DB8
Sep 24, 2002 05:54 PM
