knock sensor install question?
Old Jul 25, 2002 | 10:09 AM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
Default knock sensor install question?
i am installing one into a b18b1 block. on the c-speed site, they show a spot to tap on the alternator bracket. i can't work it in that area because the tight space (engine in the car). i went ahead and drilled and tapped a hole on the front of the block...one of the holes above the ac bracket. i didn't know if it was necessary to drill all the way through to coolant space. is it necessary to function properly, to have the knock sensor exposed to coolant? thanks. by the way, i know the hole i hit is not a oil channel in case i have to drill out some more.
Old Jul 25, 2002 | 10:18 AM
Spade's Avatar
Default Re: knock sensor install question? (not so civic)
Yes, the knock sensor is supposed to be in the coolant.
Hence the fact that you should empty the coolant when replacing one.
1fatcat
May 23, 2011 10:11 PM
moz92
Oct 12, 2007 11:20 AM
donldon
Oct 10, 2006 04:30 PM
pezzy
Sep 3, 2004 02:49 PM
gaydm.accord
Nov 30, 2003 01:50 PM
