what does the burning of a clutch smell like
Old Sep 10, 2008 | 09:47 PM
ibr_adam09's Avatar
Default what does the burning of a clutch smell like
i was just wondering becuase latley i was doing a few burnouts, and i what to know the difference between tires burning and clutch buring.
i got a little more carefull b/c last time i " burned out " the car was sawying from left to right about a foot wide from either side, moving forward slightly and at the same time ,there was a buring smell but i hardly saw any smoke from tires. the clutch i have is prettry expensive and i did let go of the clutch ( poping it ) was it a tires spinning or did i slipp the clutch ? the engine was rev around 3 ,4 k
btw i drive a 92 accord with a 2001 h22 prelude engine and trans and i dont do BO often just on moody occations , also later that day i was checking the clutch by driving , i did the stall test , the rpm = speed test and driving at higher speeds in 4th gear and 5th . the car passed i didnt feel any slippage nor i had that smell again. does that mean it is still good ?
Modified by ibr_adam09 at 11:01 PM 9/10/2008
Old Sep 10, 2008 | 09:49 PM
hondatuningboi96's Avatar
Default Re: what does the burning of a clutch smell like (ibr_adam09)
smells like rubber
Old Sep 10, 2008 | 09:54 PM
Default Re: what does the burning of a clutch smell like (hondatuningboi96)
but you won't be able to tell just by doin burnouts u have to drive the car. But just by doin burnouts and the engine just taching away and no tire smoke that means you have a problem buddy. Good luck with ur next clutch install!!!
Old Sep 10, 2008 | 10:01 PM
ibr_adam09's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondatuningboi96 &raquo;</TD></TR><TR><TD CLASS="quote">but you won't be able to tell just by doin burnouts u have to drive the car. But just by doin burnouts and the engine just taching away and no tire smoke that means you have a problem buddy. Good luck with ur next clutch install!!! </TD></TR></TABLE>
Old Sep 10, 2008 | 10:12 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ibr_adam09 &raquo;</TD></TR><TR><TD CLASS="quote">
later that day i was checking the clutch by driving , i did the stall test , the rpm = speed test and driving at higher speeds in 4th gear and 5th . the car passed i didnt feel any slippage nor i had that smell again. does that mean it is still good ?</TD></TR></TABLE>
what about on a steep hill that's how I noticed mines or on some kind of incline but if u didn't have that smell or didn't have any slip we'll u good to go then.
Old Sep 10, 2008 | 10:13 PM
ibr_adam09's Avatar
i live on flat land,
Old Sep 10, 2008 | 10:18 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ibr_adam09 &raquo;</TD></TR><TR><TD CLASS="quote">i live on flat land, </TD></TR></TABLE>
U should be good then but i noticed on mines when my car car was goin up a hill i noticed it was cutting back like it was slipping.
Old Sep 11, 2008 | 12:45 AM
johnlear's Avatar
Banned
Smells quite similar to overheated brake pads, which shouldn't be surprising since the friction driven plate friction linings are made from a fairly similar kind of substance to brake pads.
Old Sep 11, 2008 | 09:24 AM
TOAB's Avatar
It is going to smell nothing like tires. Burning asbestos, or metal would be the best way I could describe it... but you'll know if the clutch slips long before it starts burning to the point where the smell is noticeable. Once you can notice a smell you might as well find a new flywheel or find a machinist that can turn it for you.
Old Sep 11, 2008 | 01:59 PM
radiuslight's Avatar
to me it smells great....I love the smell of a burnt out clutch quemado in the mornin!
Old Sep 11, 2008 | 02:13 PM
Brad_and_the_acc's Avatar
Burnt clutch = smells like money
Old Sep 11, 2008 | 09:02 PM
Default Re: what does the burning of a clutch smell like (radiuslight)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by radiuslight &raquo;</TD></TR><TR><TD CLASS="quote">to me it smells great....I love the smell of a burnt out clutch quemado in the mornin! </TD></TR></TABLE>
Not to me a clutch job is not nothing to play with especially if one person is installing it in their driveway
Old Sep 12, 2008 | 07:08 AM
TOAB's Avatar
Not to me a clutch job is not nothing to play with especially if one person is installing it in their driveway </TD></TR></TABLE>QFT I've got to do mine within the next month or so... And this time I won't have a garage with all my tools.
Splitting the Tranny from the block while both are still in the car is a pain in the ***.
Old Sep 12, 2008 | 07:13 AM
sxm5369's Avatar
Default Re: what does the burning of a clutch smell like (TOAB)
I'm with you, with being busy with work mine turned into a week long job.
wwolf771177
Mar 10, 2012 04:32 AM
FlewByU352
13
Jul 12, 2009 05:29 AM
dylokjai
Dec 25, 2006 01:58 PM
98cwitr
Dec 29, 2002 10:39 PM
LOwrestling2001
May 26, 2002 03:28 AM
