accord with h22 ecu question
Old Sep 10, 2008 | 07:48 PM
ibr_adam09's Avatar
Default accord with h22 ecu question
i just joined the forums.
any ways, i have a 92 accord that i am working on at an autobody at school that has an h22 dropped in it.
one day i was driving and my engine light was on, so i jumped the wires to have the codes flash. i get code 12 ( long flash , 2 short flashes ) which is my egr valve lift senser.
does this mean i need to replace it, inspect it ,or is it faulty reading , i dont feel or see any symptoms from engine.
p.s another question , in the h22 motor, there is a hole covered by a rubber cap , if you move the cap ,you get a slight view of the flywheel from top. what is it for, just to check the flywheel ?
Old Sep 10, 2008 | 08:15 PM
TheMuffinMan's Avatar
He knows where you live!
You're referring to the rubber plug near the block ID? Then yes that is normal. I'm personally not sure of what its use is but it's supposed to be there.
If it's a bad sensor code then I'd:
1) Make sure it was there
2) Make sure it wasn't unplugged
3) Make sure the wiring looked ok (to ECU and sensor)
4) Replace the sensor if all the above were good
Old Sep 10, 2008 | 09:15 PM
90whiteaccord's Avatar
Default Re: (TheMuffinMan)
the ruber cover is for timing the ignition. u need to use a timing light to do it
metal craft
Jan 25, 2008 03:47 AM
mslate
Jul 26, 2006 04:57 AM
AccordRacing
May 26, 2005 08:14 PM
jdmcivicferio
Mar 21, 2003 08:48 PM
