Going from LS to B20b
Old Sep 10, 2008 | 05:03 PM
EFinawesomeman's Avatar
Default Going from LS to B20b
I have a 91 DX with an LS in it, can i use my harness that im using now and my TD23-u distributor and PR4 ecu with the B20B? I'm looking to do the swap soon. just need something slower.
Old Sep 10, 2008 | 05:25 PM
Deetz's Avatar
Crazy Honda Guy
Default Re: Going from LS to B20b (EFinawesomeman)
Just drop it in, nothing what so ever should need to be changed from an ls swap
Old Sep 10, 2008 | 05:27 PM
Deetz's Avatar
Crazy Honda Guy
Default Re: Going from LS to B20b (Deetz)
btw, what do you mean you need something slower? You know a b20 is faster, right?
Ass$nyper's Avatar
Pirate General...YARRRR
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deetz &raquo;</TD></TR><TR><TD CLASS="quote">Just drop it in, nothing what so ever should need to be changed from an ls swap</TD></TR></TABLE> intake mani will need changing.
Old Sep 10, 2008 | 06:13 PM
89hatcher's Avatar
haha...if you want something slower put a sohc motor back in.
Old Sep 10, 2008 | 06:19 PM
Deetz's Avatar
Crazy Honda Guy
Default Re: Going from LS to B20b (***$nyper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ***$nyper &raquo;</TD></TR><TR><TD CLASS="quote"> intake mani will need changing.
True, but he's already got that from the LS, he shouldn't need any more parts unless a new clutch is in order
Old Sep 11, 2008 | 08:04 AM
In torque it is faster maybe? I knew about the intake manifold ill probably go with an aftermarket one anyway. I just needed to make sure so I didnt run into any problems. Thanks alot for the help!
Old Sep 11, 2008 | 08:16 AM
Ass$nyper's Avatar
True, but he's already got that from the LS, he shouldn't need any more parts unless a new clutch is in order</TD></TR></TABLE> Touche
Old Sep 11, 2008 | 09:32 AM
n dub's Avatar
I've got the same swap in my CRX right now. Origionally i had a B18B1 then blew the motor racing it so i bought a B20B. Its an increadibly easy swap to do, everything bolts the exact same. The only thing i had to do was switch the B18 distributer, alternator, intake manifold, and exhaust manifold, onto the B20 because the B20 is a different Obd than the B18 i had.
Lasty K
Aug 7, 2007 01:51 PM
Huntley2147
55
Jun 23, 2007 01:30 PM
phantasticphan
Jan 18, 2007 11:20 AM
ELSUICIDA
16
Nov 22, 2006 05:09 PM
boostaddict.com
Nov 5, 2004 06:18 AM
