Clunking Sounds
Old Sep 10, 2008 | 02:35 PM
corince06's Avatar
Default Clunking Sounds
i just replaced both of my cv shalfts because they went bad and i am still hearing a clunking sound on the driver side when i turn...i have a couple of bad ball joints and was wondering if they could be making the sound...i was also told that it could be the steering rack has gone bad
Old Sep 10, 2008 | 03:06 PM
batallic's Avatar
Default Re: Clunking Sounds (corince06)
ball joints make a bed spring sound
Old Sep 10, 2008 | 03:09 PM
ejprimo's Avatar
Default Re: Clunking Sounds (batallic)
check your sway bar endlinks.
Old Sep 10, 2008 | 03:55 PM
grandtheftlunchbox's Avatar
bad ball joints doint always make that horribly annoying squeaking sound. it is very likely that your ball joints are the culprits. i'd replace those as soon as you can, they can leave you stranded on the side of the road with your car dragging on the ground if you let them go long enough.
William1991b
Oct 18, 2017 09:57 PM
JReal
Suspension & Brakes
Sep 25, 2009 02:29 PM
PatrickGSR94
Suspension & Brakes
19
Nov 29, 2008 06:09 AM
stevescivic
25
Jan 21, 2008 07:09 PM
osu luder
Jan 11, 2003 07:04 AM
