Car barely runs-Please help!
Old Sep 10, 2008 | 02:21 PM
alexm's Avatar
Default Car barely runs-Please help!
Yesterday my car all of a sudden started pulsing/sputtering, not in rpm though. I was running fairely empty, so I figured it was just running out of gas, but more gas didn't change a thing. I believe it's something to do with the fuel system, I'm throwing IACV which is from before, and now heated O2 and Injectors. I replaced the O2, injectors, and reset the ECU. Codes still all show, and still the same symptoms. I changed the fuel filter, and fuel pump as well, still the same issues. Car won't rev past 3500, and sputters constantly. Exhaust is also letting out some sort of fluid out the back, has no distinct smell though. Spark plugs, plug wires, dizzy, air filter, 02 sensor, all of that jazz was replaced 4000kms ago. I got no idea where to look now, I've tried everything I can think of. Any suggestions?
Old Sep 10, 2008 | 08:24 PM
srmofo's Avatar
Default Re: Car barely runs-Please help! (alexm)
your car is in limp mode...the fluid is probaly raw fuel, have you actually checked to make sure you have spark? dont just assume the parts are good because they are newer...CHECK FOR SPARK, and what is your fuel pressure at
Old Sep 10, 2008 | 08:37 PM
alexm's Avatar
Default Re: Car barely runs-Please help! (srmofo)
How do I check for fuel pressure? I need some sort of gauge I would assume to hook up the the fuel regular on the fuel rail yeah? If I put my finger on it, it feels like there's hardly any suction, if any. How could that be caused though? Lastly, how do I check for spark (beak me)
Old Sep 11, 2008 | 11:34 AM
BLACKLIST138's Avatar
how many threads do you need to explain incorrectly what problems you are having.
Old Sep 11, 2008 | 03:11 PM
alexm's Avatar
I know I know. Just lookin' for some help here, I've tried everything I can think of.
Old Sep 11, 2008 | 03:12 PM
srmofo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alexm &raquo;</TD></TR><TR><TD CLASS="quote">How do I check for fuel pressure? I need some sort of gauge I would assume to hook up the the fuel regular on the fuel rail yeah? If I put my finger on it, it feels like there's hardly any suction, if any. How could that be caused though? Lastly, how do I check for spark (beak me) </TD></TR></TABLE>
uhhh what??? Take it to a shop, cough up the dough, and drive home in a running car. You obviously dont have the tools or hands on ability to fix this yourself
Old Sep 11, 2008 | 06:38 PM
alexm's Avatar
My neighbour has a fuel pressure gauge. I've never done it, and he was curious how I thought it should be done, so I was asking. I'm sorry if I asked the wrong questions, I'm new to this aspect.
Old Sep 12, 2008 | 03:42 PM
srmofo's Avatar
check for spark at all cylinders, then check fuel pressure, then post back
manintux
Jul 7, 2008 05:52 PM
keviiinnnnn
15
May 9, 2008 12:14 PM
flyguy0086
Jan 23, 2007 10:11 PM
tallguy
18
May 5, 2005 03:47 PM
BoomBoom0
Feb 8, 2003 02:26 PM
