ls/v should i boost
Old Sep 10, 2008 | 02:04 PM
pokmijn's Avatar
Default ls/v should i boost
b18a1 blcok
Eagle rods and weisco pistons
Block guarded
ARP head studs.
Crankshaft has been shaved and balanced.
Flywheel has been shaved.
Compression ratio is at 12.5 to 1
b16 head
Type R intake manifold
Type R springs, retainers and valves.
Type R Camshaft
Adjustable cam gears
w/b16 tranny
just finish this setup for about 6k miles and miss my turbo would this be a good setup to add boost like 6 psi. cause the compression is kind of high.
Old Sep 10, 2008 | 02:13 PM
SUPREMEgarage's Avatar
Default Re: ls/v should i boost (pokmijn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pokmijn &raquo;</TD></TR><TR><TD CLASS="quote">b18a1 blcok
Block guarded
ARP head studs.
b16 head
Type R Camshaft
w/b16 tranny
Compression is a little on the high side. I'd throw some low comp pistons in there and boost 10psi.
TonytheTiger on here is boosting with 11.5:1 pistons a believe... but this was a while back. ITBs boosted sleeper.
Old Sep 10, 2008 | 02:17 PM
pokmijn's Avatar
Default Re: ls/v should i boost (SUPREMEgarage)
that means i have to rip my motor apart again to boost. im probably jsut gonna wait if my high compression isn't safe to boost.
Old Sep 10, 2008 | 02:55 PM
BoSox46GSr's Avatar
I as well would not boost with that high of compression.
Old Sep 10, 2008 | 03:04 PM
pokmijn's Avatar
Default Re: ls/v should i boost (BoSox46GSr)
ok thanks guys i guess the boost has to wait
Old Sep 19, 2008 | 12:29 AM
pokmijn's Avatar
im trying to be in the 12's could i just go like 3-4 psi of boost i dont want to rip the motor apart cause i dont have the time and money i already have a turbo kit. i know my compression is high but will i be ok with 3-4 psi am already running 13.4
here is my setup again
b18a1 blcok
Block guarded
ARP head studs.
b16 head
Type R Camshaft
w/b16 tranny
Old Sep 19, 2008 | 01:42 AM
Horseofcourse's Avatar
3-4 psi isnt even worth it
Old Sep 19, 2008 | 03:32 AM
billabong's Avatar
forget about boosting, sell the kit and keep it na
Old Sep 19, 2008 | 12:34 PM
pokmijn's Avatar
Default Re: (billabong)
yeah i know 3-4 isn't worth it i guess i can sell it and then do some porting and vavle jobs. hopefully that will get me into the 12's anybody know what i can do to be in the 12's that wont cost so much cause i wont get much form my turbo kit.
my car is a 1990 DA full interior. dont want to take my interior out and put it back in. let me know what you guys think.
Old Sep 19, 2008 | 01:13 PM
jspec-integ Ls's Avatar
Default Re: (pokmijn)
a good suspension, replace all suspension bushings, slicks, light weight rims and a good 60ft time
Old Sep 19, 2008 | 01:18 PM
HondaKyle's Avatar
sell your motor and get a B20b, boost the B20b and it will be faster then the built motor you sold.
Old Sep 21, 2008 | 01:37 AM
pokmijn's Avatar
Default Re: ls/v should i boost (HondaKyle)
im gonna past on the b20, my bro just purchase me some slick ill try it with slick hopefully that will put me in the 12's...i just sold my turbo kit to this kid for 1100 ill probably invest that into the motor as well, should i replace my type r cams for CTR cams, and put in lsd.
Old Sep 21, 2008 | 03:13 AM
fcfromhell420's Avatar
yes you can boost on that high of compression, but you would need a rock solid tune, im talking 100% perfect tune, i heard of the local tuner around hear was running something ridiculous like 14:1 on boost, but something happened, like he blew a vacuum hose or something and he leaned out real quick and kaboom, but it had nothing to do with the engine, turbo or tune set up he had it was just something stupid that went wrong, don't remember specifics
Old Sep 21, 2008 | 02:26 PM
pokmijn's Avatar
Default Re: ls/v should i boost (fcfromhell420)
really im gonna have a talk with my local tuner then see if he had every tune a high comp. turbo before, but this guys does very good tune though. His name is Tom from REVSPEED in fresno.
Old Sep 21, 2008 | 05:18 PM
wegotmorrison's Avatar
Turbo FTL
digital sol
Jun 3, 2011 09:15 PM
pokmijn
Sep 13, 2008 08:58 PM
1995Civiccx
Jul 16, 2007 04:44 PM
DOHC VTEC EG
Apr 28, 2004 06:23 PM
