Transmission & Drivetrain Gearboxes, Differentials, Clutches
Automatic transmission fluid Change question?
Old Sep 10, 2008 | 08:16 AM
jetspeedz's Avatar
Default Automatic transmission fluid Change question?
I have a 98 civic hatchback and i looked in the owners manual and it states 2.9qt-change and 6.2-total. I have never changed the tranny fluid myself so im going to give it a shot since i change my oil regularly figured it can't be too hard.
My only question is how to do a full flush? or should i just change it once with the 2.9qt and call it a day. I don't beat on the car its just a commuter.
thanks
Old Sep 10, 2008 | 08:23 AM
Evs-One's Avatar
Solbros Owns Me
Default Re: Automatic transmission fluid Change question? (jetspeedz)
2.9 is drain and fill capacity.
The 6.2 is if it were completely dry(lines, torque converter, etc).
Only way to properly do a "flush" is to hook the lines up to a flush machine(spendy). If you are not having problems, a simple drain and fill is just fine. You do not get all of the fluid out, that's why routine maintenance is key to getting the longest life from your Honda AT.
You can also perform a triple flush.
1. Drain and fill trans.
2. Run front wheels off the ground in D at 30-40 mph for a few minutes.
3. Repeat for twice(use 9 quarts total).
Old Sep 10, 2008 | 08:25 AM
jetspeedz's Avatar
Default Re: Automatic transmission fluid Change question? (Evs-One)
Great thanks for the quick response. I will take your advice and do a simple flush and if its really bad ill do a triple flush...
One question though do i need to stick with the Honda ATF or can i get what they have at Pepboys ?
thanks
Old Sep 10, 2008 | 08:28 AM
Evs-One's Avatar
Solbros Owns Me
Honda ATFZ1 for sure.
Honda transmissions are different than most manufacturers and require a specific fluid.
Old Sep 10, 2008 | 08:29 AM
jetspeedz's Avatar
Great thanks, ill stick with the honda atf.
dankoty
Honda CR-V & Element
11
Jan 8, 2017 03:38 PM
Mike8ike
Jul 30, 2013 05:20 AM
Blacknight117
30
Jul 3, 2011 07:25 AM
baiwldrnner
Honda Civic (2001 - 2005)
Jul 18, 2007 09:55 PM
jiGGaMein
Aug 16, 2002 01:20 PM
