Need a new throttle body! help please..
Old Sep 10, 2008 | 04:07 AM
19ekcoupe96's Avatar
Default Need a new throttle body! help please..
to start off..i have a 93 civic ex coupe with a 90 ls in it..well its come time to get a new throttle body, being that my idle screw is stripped...so im trying to find out which junkyard throttle bodies are direct bolt on...
now iv searched before and i read that an f22 throttle body will bolt right up which i tried (out of a 93 accord) and didnt succed...the holes didnt line up at all...
can anobody tell me what the best thottle body(hoping for a bigger one) would be that i might find at a junkyard..thank you
Old Sep 10, 2008 | 09:02 AM
gsrhatch2356's Avatar
Default Re: Need a new throttle body! help please.. (19ekcoupe96)
B, D, H series motors should all have the same bolt pattern. wheather it has the right plug in for tps and map is another question I cant answer. if you find out that a 95 gsr one will fit for sure, I just got my 70mm billit one and would sell for 10bucks plus shipping but make sure it fits first cause its only going one way.
Old Sep 10, 2008 | 09:13 AM
DTA-Zombie's Avatar
yes b,d,h are all the same - I would use any available b series or an H22's you may have to swap your sensors worst case but that isn't ****
Ezequiel216
Engine Machining & Assembly
Dec 4, 2015 05:06 AM
mrbsponge
Aug 25, 2008 12:57 PM
crispy93
Apr 11, 2007 09:27 AM
McNizzle
Aug 19, 2004 02:25 PM
